Go to Post All I need now is a plow atachment for this year's robot - team 3311 [more]
Unread 30-01-2003, 11:15
Charlie B Charlie B is offline
Charlie B will become famous soon enoughCharlie B will become famous soon enough
Disabling drill transmission clutch
How have you done it? We have considered brazing the two clutch contact rings together, but they look like they are made of sintered metal, and would probably pretzel under heat.
Charlie Buckner, P.E.
Team 900 Mentor
Durham, NC
Unread 31-01-2003, 09:57
P.J. Baker's Avatar
P.J. Baker P.J. Baker is offline
needs a clever user title
FRC #0177 (Bobcat Robotics)
P.J. Baker is a glorious beacon of lightP.J. Baker is a glorious beacon of lightP.J. Baker is a glorious beacon of lightP.J. Baker is a glorious beacon of lightP.J. Baker is a glorious beacon of light
Replacing the spring with a metal tube and/or forcing the two spring loaded metal tabs into the down position will lock up the clutch.
P.J.
Unread 31-01-2003, 10:02
Thanks. We figured out last night that the clutch is locked when the the outer sleeve is turned all the way to the "drill bit" symbol. Duhhh.
Team 900 Mentor
Durham, NC
What is it ESSENTIAL to do to a drill transmission... Iain Motors 12 04-02-2003 21:56
Locking the drill motor clutch? Rick Gibbs Motors 1 06-01-2003 09:46
BOSCH Drill Transmission Assembly archiver 2001 2 23-06-2002 22:08
Mating gear with drill transmission thedillybar Technical Discussion 0 13-02-2002 21:08
