Go to Post Yeah those design flaws kill you in the end. You especially hate finding out about them in competition. - Koko Ed [more]
Unread 30-01-2003, 18:52
rust710's Avatar
rust710 rust710 is offline
#0862 (Lightning Robotics)
rust710 is an unknown quantity at this point
Send a message via AIM to rust710
Me being a programmer and all should probaly not answer but here goes.
The Pump will be directly connected to the tanks giving you as much pressure as want up to 120 psi. Then before the air can be used it must go through a regulator which will regulate it to a max of 60 psi. As for the relief valve on the pump I am not sure why yours is not allowing the full pressure.
Need a FIRST Robotics control system kershawrobotics General Forum 3 07-07-2003 09:49
Auto Air Pump Code zorro Programming 25 05-01-2003 16:50
control system worth more than $500 archiver 2001 8 24-06-2002 02:00
New Innovation FIRST control system and the dashboard archiver 2000 0 23-06-2002 22:15
Pneumatic pressure sensor Curtis Williams Pneumatics 3 04-02-2002 20:09
