Go to Post The championship event is a meta-game of inches. People will complain about unbalanced/unequal divisions, whether you think it's silly or not. - PayneTrain [more]
Unread 30-01-2003, 21:12
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
Originally posted by RobDeCotiis
we have our pressure switch connected directly through a relay going to the pump.. the pressure switch cuts power to the relay, the relay cuts power to the pump.. only problem is that it shuts off about 115 and goes back on at like 95.. any way to fix this?
This is NOT a legal (or safe) way of doing it. The pressure switches just aren't designed to handle all the current drawn by the compressor and relay. You MUST use the switch to control the relay from within the software.
spike for pressure switch? Rob Colatutto Rules/Strategy 4 23-02-2003 15:42
pressure switch Michael Long Pneumatics 1 11-02-2003 11:21
lost pressure switch Josh Hambright Pneumatics 0 29-01-2003 08:30
pressure switch piconysm Technical Discussion 5 14-02-2002 23:15
Error found in programming for the pump and pressure switch sjharobotics Programming 4 06-02-2002 17:46
