Go to Post Temp wiring is always bad but it is made worse when dealing with a $1000 part. You wouldn't try to lash a makeshift power source to your PC. - Al Skierkiewicz [more]
Unread 31-01-2003, 03:52
D.Viddy's Avatar
D.Viddy D.Viddy is offline
AKA: Dylan Vester
FRC #3176 (Purple Precision)
D.Viddy is an unknown quantity at this point
There is only a single because the one switch acts as two switches. It opens as 115 and it closes at 95 or something like that. So it can easily be programmed like it were two.
Dylan Vester - (Programmer)
Running a P4 1.8 Ghz
Team 998, We can't win...
spike for pressure switch? Rob Colatutto Rules/Strategy 4 23-02-2003 15:42
pressure switch Michael Long Pneumatics 1 11-02-2003 11:21
lost pressure switch Josh Hambright Pneumatics 0 29-01-2003 08:30
pressure switch piconysm Technical Discussion 5 14-02-2002 23:15
Error found in programming for the pump and pressure switch sjharobotics Programming 4 06-02-2002 17:46
