Go to Post Okay guys I am enabling the robot. Honestly I have know idea what it is going to do. SO MOVE!! - JulieB [more]
Unread 02-02-2003, 20:55
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Originally posted by ReggieB
We aren't using the keyed shaft, because we are using this to pull a wire cable. We attached a "barrel" to the black piece to wind up the cable. It will be mounted upside-down most likely, allowing it to slip off after a while.
Hope that helps
You shouldn't place load like that directly on the gear coming out of the motor, it should still be supported by a shaft, pillow blocks and bearings. How hard will you be pulling on this cable?
Complete Drill, Seat, and Window motors for trade archiver 2000 0 23-06-2002 22:16
