Go to Post Gracious Professionalism, it's hard to describe, but I sure know when I'm not living up to it. - rsisk [more]
Unread 03-02-2003, 19:24
rust710's Avatar
rust710 rust710 is offline
#0862 (Lightning Robotics)
rust710 is an unknown quantity at this point
Send a message via AIM to rust710
Re: its ok
Originally posted by KZos550
Hey, at least I got some use practicing quoting...
Can't you just hit the quote button toward the bottom of the post and delete what you don't want? Like what I did above.
Andrew Radamis
Programmer on 862
info@lightingrobotics.com
A better autonomous method.. randomperson Programming 4 24-02-2004 18:02
variable? manodrum Programming 11 01-04-2003 17:20
autonomous mode problem on field Chris_C Programming 17 26-03-2003 19:11
Autonomous Kill Switch UCGL_Guy Programming 8 15-01-2003 17:39
Need help with 255 Variable Joseph F Programming 18 26-02-2002 14:49
