Go to Post Too bad MI isn't allowed to participate in FTC - Cory [more]
Unread 03-02-2003, 23:52
wwrye wwrye is offline
#0057 (Leopards)
wwrye is an unknown quantity at this point
Angry redundance
Mike, what is up with all the identical code, don't you think you could go with the flow of the main loop and just do something like this:
':::Timer variables
cntr_cycles 	VAR byte
seconds		VAR nib '15 sec timer,make byte for more time
seconds = 0           'same as your realtime variable
cntr_cycles = 0       'same as your time variable
if auton_mode = 1 then do_auton
	'non autonomous code
goto skip_auton
do_auton:
':::15 second TIMER::
	if cntr_cycles >= 38 then update_timer
	goto skip_update_timer
	update_timer:
		seconds = seconds + 1
		cntr_cycles = 0
	skip_update_timer:
		select seconds
			case <6  'until seconds = 5
				drive_R = 180	'put drive commands accordingly
				drive_L = 180
			case <11
				drive_R = 127
				drive_L = 127
			case <16
				drive_R = 64
				drive_L = 190
		endselect
	cntr_cycles = cntr_cycles + 1 + delta_t
	'debug ?cntr_cycles, tab, ?delta_t, tab, ?cntr_cycles, cr
Questions/comments, pm me
Timing of nats for next year Ian W. Championship Event 13 03-03-2003 18:28
Way back there. Size of Nationals, and a solution archiver 2001 23 24-06-2002 03:28
what is or isn't a timing belt? archiver 2001 6 23-06-2002 23:26
two sided timing belt archiver 2001 3 23-06-2002 22:34
Dual Sided Timing Belts Lachuck894 Technical Discussion 9 14-01-2002 10:10
