Go to Post FIRST is good for us. It is good for our own Children. Don't give up, even if you are as tired as I am! - Kyle Hughes [more]
Unread 04-02-2003, 15:12
Thunder360 Thunder360 is offline
#0940 (Digital Demolition)
Thunder360 is on a distinguished road
Well, I got it all built and it using the 2 chippy's and it runs like a dream, it has pin point up shifting, but it takes a lil more to down shift. I set it for 4 speeds insted of 3 like I was thinking. first gear is slow and very powerfull, and it works itself up to 4th gear and it will push our robot with the speed and torque about even with each other.
The only bad part is every time we shift gears we use air, and our compresser is always going. Thank god that only the drive train uses Pneumatics!!!
I also took some advice and built a second 1 speed drive train, that will bolt right into the existing holes, if my 4 speed happens to fail before, or at the compatition.
Thanks Alot, there will be pictures up soon
"Who needs Battle Bots, Ive got US FIRST!!!"
transmission Gregory Frechou Technical Discussion 16 19-11-2003 23:37
Our Tranny EIROBOTICS86 Robot Showcase 1 24-02-2003 18:06
tranny designs Don Technical Discussion 18 15-07-2002 21:04
Which teams are using a transmission this year Todd Derbyshire Scouting 10 08-04-2002 10:21
Shifting Gears -- Anton Abaya Technical Discussion 26 22-01-2002 21:49
