Go to Post When a team is a team, anything is possible - Bharat Nain [more]
Unread 29-01-2003, 21:08
Greg McCoy's Avatar
Greg McCoy Greg McCoy is offline
boiler up!
FRC #3940 (CyberTooth)
Greg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond repute
Send a message via AIM to Greg McCoy
Yes! He explained it better than I did. One thing that I would add is if you are really strained for RAM is that you could keep the counter a byte and if you need numbers bigger than the byte will supply, just add steps until you get the length you need.
Unread 29-01-2003, 22:59
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
Originally posted by mjt902
Once again you correct me!!! Oh, I'm lazy anyway but thanks for the free code. Only one question have I:
where'd you get the 8 from in SELECT(loopCntHigh<<8 + loopcnt)
i think you and i are on the same page (only i'm on a different plane) , and its great learning from you!!!
The 8 will shift it left by 8 bits, leaving enough space for the byte (8-bits) to fill in the newly created free space.
Here's an example:
Assume loopCntHigh is 3 (0011 in binary), meaning we've looped through 256 values of loopCnt 3 times.
Assume loopCnt is 199 (11000111).
Then: loopCntHigh<<8=001100000000
Add loopCnt: 001111000111, which is 967. This makes sense as 256*3+199=967.
Does that make any sense? Bit shifting operations are always messy, but sometimes they are the easiest solution to problems like this (a single number spanning multiple variables).
Unread 30-01-2003, 08:46
Caleb Fulton's Avatar
Caleb Fulton Caleb Fulton is offline
Z = Z^2 + C ......WHEEEE!
AKA: aXvXiA
#0461 (West Side Boiler Invasion)
Caleb Fulton has a spectacular aura aboutCaleb Fulton has a spectacular aura aboutCaleb Fulton has a spectacular aura about
Send a message via AIM to Caleb Fulton
Rob: Is there a place online that documents the mathematical limits of PBasic?
I ask because I like your bytevariable<<8+nibblevariable trick
Unread 30-01-2003, 20:54
Depends on what limits you are talking about. The Stamp manual from Parallax contains all the math operators, etc that the Stamp supports, but it doesn't give many good examples of how you would use most of it.
For me, I've picked most of it up doing a LOT of C/C++ stuff, much of which includes bit-operations such as this. Randall Hyde's assembly language tutorial (http://webster.cs.ucr.edu/Page_asm/A..._ArtofAsm.html) has some really good info on binary math and logic, but it isn't exactly and easy read. Like always, I'm available to answer any questions anybody comes up with, so feel free to drop me a PM or email.
--Rob
Unread 01-02-2003, 15:29
Mike537Strategy Mike537Strategy is offline
#0537 (Charger Robotics)
Mike537Strategy is an unknown quantity at this point
I'm trying to use the original timer code from the first thread in a simple dead reckoning pattern. My code has the time calculator directly after the SERIN, has 2 lines of code changing the wheel numbers for the SEROUT, then the SEROUT. It loops this until realtime = whatever time I want. It goes forward, turns right, forward, right, forward, right, then forward. The problem is that after the first forward (Which works perfectly), it just turns right until I turn off the robot. Any ideas why? The variables are the same as the default, delta_t is declared and set to 1 in intilization. The forums aren't being nice and the SERINs are all on one line in the actual code.
do
   Serin COMA\COMB, INBAUD, [oi_swA,oi_swB,rc_swA,rc_swB,p2_x,p1_x,p4_x,p3_x,PB_mode,packet_num,p2_y,p1_y,p4_y,p3_y,p2_wheel,p1_wheel,p4_wheel,p3_wheel]
   time = time + delta_t + 1
   if time > 38 then
      time = time - 38
      realtime = realtime + 1
   endif
   p1_y = 254
   p2_y = 254
   Serout USERCPU, OUTBAUD, [255,255,p1_y,0,p2_y,0,127,127,127,127,127,127,
			     127,127,127,127]
loop until realtime = 2
do
   p1_y = 254
   p2_y = 0
   if time > 38 then
      time = time - 38
   endif
			     127,127,127,127]
loop until realtime = 1
do
   if time > 38 then
      time = time - 38
   endif
   p1_y = 254
   p2_y = 254
			     127,127,127,127]
do
   p1_y = 254
   p2_y = 0
   if time > 38 then
      time = time - 38
   endif
			     127,127,127,127]
do
   if time > 38 then
      time = time - 38
   endif
   p1_y = 254
   p2_y = 254
			     127,127,127,127]
do
   p1_y = 254
   p2_y = 0
   if time > 38 then
      time = time - 38
   endif
			     127,127,127,127]
do
   if time > 38 then
      time = time - 38
   endif
   p1_y = 254
   p2_y = 254
			     127,127,127,127]
"Charging into the future, one game at a time." - Team 537 motto
Unread 01-02-2003, 16:32
Don't forget to reset realtime to 0 between your sections. Or, you could change the "loop until realtime=1" to "loop until realtime=3". From quickly looking over your code, I'd guess that this is the problem.
--Rob
Unread 02-02-2003, 20:40
Anthony Kesich's Avatar
Anthony Kesich Anthony Kesich is offline
Programmer Turned Engineer
AKA: SonKenshin
#1097 (Site 3 Engineernig)
Anthony Kesich has a spectacular aura aboutAnthony Kesich has a spectacular aura about
Send a message via AIM to Anthony Kesich
Question Why make it so hard on yourselves
why are all of you making it so hard on yourselves?
just put the time counting loop at the beginning of your autonomous mode, then use if/then statements relating realtime and time. Why repeat it 7 times throughout your code along with serin again and again? plus, why worry about counting for 1 min 45 sec? unless i am extremely mistaken, the auton mode is only 15 seconds long, and i doubt you want to run your robot autonomously after that because no matter how godly of a programmer you are, human senses, adaptability, and recognization will always outdo straight computer logic.
-Anthony
C is screwing up my English--I'm ending all my sentences in semi-colons;
Horray for most things! -George Carlin
"Sure, I'll play rugby. Besides, I have a lot of experience running from really big guys who want to cream me." -Me, Freshman year
Unread 03-02-2003, 23:52
wwrye wwrye is offline
#0057 (Leopards)
wwrye is an unknown quantity at this point
Angry redundance
Mike, what is up with all the identical code, don't you think you could go with the flow of the main loop and just do something like this:
':::Timer variables
cntr_cycles 	VAR byte
seconds		VAR nib '15 sec timer,make byte for more time
seconds = 0           'same as your realtime variable
cntr_cycles = 0       'same as your time variable
if auton_mode = 1 then do_auton
	'non autonomous code
goto skip_auton
do_auton:
':::15 second TIMER::
	if cntr_cycles >= 38 then update_timer
	goto skip_update_timer
	update_timer:
		seconds = seconds + 1
		cntr_cycles = 0
	skip_update_timer:
		select seconds
			case <6  'until seconds = 5
				drive_R = 180	'put drive commands accordingly
				drive_L = 180
			case <11
				drive_R = 127
				drive_L = 127
			case <16
				drive_R = 64
				drive_L = 190
		endselect
	cntr_cycles = cntr_cycles + 1 + delta_t
	'debug ?cntr_cycles, tab, ?delta_t, tab, ?cntr_cycles, cr
Questions/comments, pm me
Unread 05-02-2003, 13:12
Steven Carmain Steven Carmain is offline
Bit Twiddler
FRC #2832
Steven Carmain will become famous soon enough
A problem is your mixing syntaxes. The goto in the beginning is 2.0, but select case is 2.5
2017 - Team 2832 Mentor
2016 - Team 6013 Mentor
2002-05 - Team 45 Software/Electrical
A robot is like a campfire: it takes a while to bulid it, and then everyone surounds it!
A world without standards is chaos. A world with standards is chaos.
Unread 05-02-2003, 17:45
There is no problem with his code. You can mix 2.0 syntax into the 2.5 without any problems. It would be better from a style perspective to have said:
if auton_mode=1 then
'auto code goes here
else
'normal here
endif
but it isn't wrong to do it the other way.
Unread 06-02-2003, 22:33
Morgoth Morgoth is offline
#0471 (Cybertigers)
Morgoth is an unknown quantity at this point
You don't need to worry abou the timing, just take your "cue" for the fifteen seconds from when auton_mode changes to zero and comp_mode (or something like that) changes to 1.
"Lock the Doors"
NASA chief flight director Leroy Cain on the loss of Columbia's signal.
Unread 07-02-2003, 01:11
But if you're doing dead-reckoning, you need to know how many seconds have passed so far so that you know what you should be doing.
Unread 07-02-2003, 19:17
#0471 (Cybertigers)
Ahhhh, now I understand. Thanks for the insight. We are going to follow the line so I didn't think of that.
"Lock the Doors"
Unread 08-02-2003, 10:32
Greg McCoy's Avatar
boiler up!
There are many ways to skin the cat, but some ways are better than others
Unread 08-02-2003, 15:00
FRC Key Volunteer Trainer
AKA: CrazyNate
Not necessarily the number of seconds, but rather the amount of time(program cycles work here) your program has been running...and it's easy enough to have a program you can "train"...i'm going to be putting together a white paper sometime later in the season about the autonomous training system I came up with for a team that I got asked to help...
Nate Smith
nsmith@smythsoft.com
Timing of nats for next year Ian W. Championship Event 13 03-03-2003 18:28
Way back there. Size of Nationals, and a solution archiver 2001 23 24-06-2002 03:28
what is or isn't a timing belt? archiver 2001 6 23-06-2002 23:26
two sided timing belt archiver 2001 3 23-06-2002 22:34
Dual Sided Timing Belts Lachuck894 Technical Discussion 9 14-01-2002 10:10
