Go to Post I <3 statistics. - Barry Bonzack [more]
Unread 07-02-2003, 03:08
JoshB JoshB is offline
JoshB is an unknown quantity at this point
There isn't a real advance or disadvance to either 2.0 or 2.5. The difference is with the programmer, which are you more comfortable with? You technically can do the same things with each, IMHO 2.5 is easier to do most things.
To the processer is makes no difference, both 2.0 and 2.5 are tokenized into the same machine code for the processer to understand. As stated above you need the newest editor to be able to Tokenize 2.5.
Other than that, you make the call as to which will do what you want it to.
Help this helps!
Broken PBASIC 2.5 Complier? Mike Yan Programming 12 01-02-2003 09:11
New Stamp Editor & PBASIC 2.5 Jnadke Programming 8 24-01-2003 07:57
RoboEmu 1.09 (supports PBASIC 2.5) rbayer Programming 22 21-01-2003 17:22
PBASIC 2.5 Questions Noah Programming 6 10-01-2003 19:26
PBASIC 2.5 answer from Parallax JasonS Programming 6 07-01-2003 19:21
