Go to Post Gracious professionalism... otherwise, the program has failed. - Yan Wang [more]
Unread 08-02-2003, 12:45
Specialagentjim's Avatar
Specialagentjim Specialagentjim is offline
"I am a Meat Popsicle"
AKA: Jim Martz
None #0108 (SigmaC@T)
Specialagentjim is a splendid one to beholdSpecialagentjim is a splendid one to beholdSpecialagentjim is a splendid one to beholdSpecialagentjim is a splendid one to beholdSpecialagentjim is a splendid one to beholdSpecialagentjim is a splendid one to beholdSpecialagentjim is a splendid one to behold
Send a message via AIM to Specialagentjim
Originally posted by x_cat_SHAUN
I dont want lighting i need lightning as in the thunderstorm.I checked the plug-ins but we cant get them.Is there any other way?
OOoooo, ::smacks self across head:: duh, sorry, gotcha.
There is a digimation plugin that can do lightning for you. Ironically, its called Digimation Lightning. It allows you to select two objects and create a lightning bolt between them.
You could also use a line also, make it renderable, and have it bounce around from keyframe to keyframe.
In either of these situations, you then need to create a lens effects glow. First, apply a material to the objet. Next, in the material editor, there is a button below the preview spheres, that has a 0 in it, that is the effets ID button. Switch that to Effects ID 1. Now, go to Render>Effects. Click add... and then add a lens effect.
You see here you need to add the GLOW from the list on the left to the list on the right. Once you do that, scroll down to the bottom, and where it says Material ID, check that box and make sure its set for 1.
The result of this should end up being that the object that you applied the material to will now glow. The other settings you might want to adjust (lower most likely) would be next to the options tab, in the parameters tab. Adjust the size to make the glow smaller and more dense, more like lightNing...heh.
Okay, if i missed anything, sorry..im in the middle of working on our animation..heh, lemme know if i did! Later yall
Curie Division 2005 Champions (175, 33, 108)
UCF 2005 Website Award
Midwest 2005 Delphi's Driving Tomorrow's Technology
2004 UCF QuarterFinalists (1065, 86, 108)
UCF 2003 Regional Champs/Entrepreneurship Award
Midwest Regional 2003 Leadership In Controls/Website award
Nationals 2003 Quarter Finalists
Robot Rodeo 2003 Champions (Alliance: 180 and 186)
AIM S/N: Specialagentjim
Questions regarding textures in 3D Studio Max Ryan Dognaux 3D Animation and Competition 6 16-02-2003 14:26
3d Studio Max 4 Modeling CyberDefender 3D Animation and Competition 0 29-10-2002 12:23
3-d studio max archiver 2001 21 23-06-2002 23:28
Question about 3D Studio Max ee_capp 3D Animation and Competition 0 01-02-2002 15:49
3D Studio Max AJ Howard 3D Animation and Competition 1 18-01-2002 17:58
