Go to Post Because nothing says safety like carrying a 150lb robot across a field covered in golf balls. - Kevin Sevcik [more]
Unread 08-02-2003, 15:00
FRC Key Volunteer Trainer
AKA: CrazyNate
Originally posted by rbayer
But if you're doing dead-reckoning, you need to know how many seconds have passed so far so that you know what you should be doing.
Not necessarily the number of seconds, but rather the amount of time(program cycles work here) your program has been running...and it's easy enough to have a program you can "train"...i'm going to be putting together a white paper sometime later in the season about the autonomous training system I came up with for a team that I got asked to help...
Nate Smith
nsmith@smythsoft.com
Timing of nats for next year Ian W. Championship Event 13 03-03-2003 18:28
Way back there. Size of Nationals, and a solution archiver 2001 23 24-06-2002 03:28
what is or isn't a timing belt? archiver 2001 6 23-06-2002 23:26
two sided timing belt archiver 2001 3 23-06-2002 22:34
Dual Sided Timing Belts Lachuck894 Technical Discussion 9 14-01-2002 10:10
