Go to Post Bomb squad, that grabber was the coolest way to grab a tetrahedral object in the history of grabbing tetrahedral objects. - IronVulture [more]
Unread 09-01-2002, 23:02
zorro zorro is offline
#0292 (PantherTech)
zorro is an unknown quantity at this point
Send a message via AIM to zorro
The yaw rate sensor, commonly referred to as the gyro, detects changes in rotational velocity. It can be used to detect if your robot is tipping, how fast an arm is moving, etc. It is a cool sensor to use if you have a need for it (ie balancing a bridge). I don't see much need for it in this year's game. If you want more technical details, I'd be happy to supply them.
Aux Fuse 3 (Yaw Rate) Josh Hambright Electrical 0 18-02-2003 08:22
Yaw rate sensor pin-out GregT Electrical 8 18-02-2003 00:07
Yaw Rate Sensor to 90 degrees? Bruce C. Programming 4 11-02-2003 00:36
Yaw rate sensor (gyro for the layperson) Kris Verdeyen Rules/Strategy 4 14-01-2002 00:41
Yaw Rate Sensor ImmacGirl_03 Technical Discussion 2 10-12-2001 15:15
