I think robot's should use just enough juice to totally discharge the battery after a match
. If you're not using that much, you're not using enough. Short circuit the battery if you must. I mean you wouldn't have to worry about recharge memory problems this way. On a more serious note using that much juice that quickly may cause the battery to get rather warm. |
| Keyang Motor Thermal breaker. | archiver | 2000 | 1 | 24-06-2002 00:24 |
| 60 amp Circuit Breaker Info | archiver | 2001 | 1 | 23-06-2002 22:33 |
| Circuit Breakers | ark_1230 | Electrical | 28 | 09-04-2002 23:16 |
| Where can I get 60 Amp Fuses -- that look like 30 Amp Fuses? | Anton Abaya | Chit-Chat | 4 | 12-01-2002 14:09 |
| Chain and chain breaker source? | kmcclary | Off-Season Events | 4 | 22-10-2001 22:51 |
