Go to Post I was thinking (dangerous I know) - EricH [more]
Unread 10-02-2003, 20:32
Umm Errr...
Pbasic 2.5 syntax
does anybody know where i can find a pbasic 2.5 language reference. I can't find it on the parallax website! help!
1139 Alumni
Unread 10-02-2003, 20:51
FotoPlasma FotoPlasma is offline
FotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond repute
Send a message via AIM to FotoPlasma
http://www.chiefdelphi.com/forums/pa...le&paperid=165
I played hacky sack with Andy Baker.
2001-2004: Team 258, The Sea Dawgs
2005: Team 1693, The Robo Lobos
Unread 10-02-2003, 20:54
rust710's Avatar
rust710 rust710 is offline
#0862 (Lightning Robotics)
rust710 is an unknown quantity at this point
Send a message via AIM to rust710
I don't think a full 2.5 code referance exsists. The only thing aviable is a PDF file included in the beta version that has the new syntax features. It should C:\Program Files\Parallax Inc\Stamp Editor v2.0 Beta 1\PBASIC Editor 2.0 Beta1.pdf. There is also a short cut in Start Menu->Programs->Parallax Inc->Stamp Editor 2.0 Beta 1->PBASIC Editor 2.0 Beta1.pdf.
Hope that helps.
<edit> Guess I was wrong. Oh well.</edit>
Andrew Radamis
Programmer on 862
info@lightingrobotics.com
Unread 10-02-2003, 21:50
Umm Errr...
Does anybody know anything about the new scratchpad syntax. could somebody please explain it to me.
1139 Alumni
Unread 10-02-2003, 22:22
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
It's the same as the old stuff. If you aren't familiar with that, check out the Stamp manual from Parallax's website. You should look for the PUT and GET commands.
Unread 12-02-2003, 20:36
Umm Errr...
sorry this is my first time programming Pbasic. im mainly used to PHP and C++
1139 Alumni
Unread 14-02-2003, 22:57
Raven_Writer's Avatar
Raven_Writer Raven_Writer is offline
2004 Detroit & Pittsburgh Winners
AKA: Eric Hansen
FRC #0005 (RoboCards)
Raven_Writer is just really niceRaven_Writer is just really niceRaven_Writer is just really niceRaven_Writer is just really niceRaven_Writer is just really nice
Send a message via ICQ to Raven_Writer Send a message via AIM to Raven_Writer Send a message via MSN to Raven_Writer Send a message via Yahoo to Raven_Writer
Wasn't there supposed to be syntax highlight? I looked through everything, but nothing for highlighting. I also need a little bit of help. I shouldn't be asking this since I've done a comparision between the syntax, but how is switch used?
AIM: wisprmylastbreth
EMail: nightskywriter@gmail.com
Y!: synsoflife
"ai yoru ga" -- "Love the nights"
Unread 14-02-2003, 23:35
Parallax has said from the beginning that the alpha/beta versions won't have syntax highlighting but the final version will.
There is no "switch" command. There is a SELECT...CASE...ENDSELECT structure, which does the same thing. Ie:
SELECT counter
CASE 0 TO 100
'do stuff
CASE 101 TO 200
'do other stuff
CASE 201 TO 255
'do even more other stuff
CASE ELSE
'stuff to do if none of the previous cases match
ENDSELECT
There's other things you can put after CASE also (such as a single number or an operator and a number (ie >5)), but the above code is the basics.
--Rob
Unread 14-02-2003, 23:37
AKA: Eric Hansen
SELECT counter
CASE 0 TO 100
'do stuff
CASE 101 TO 200
'do other stuff
CASE 201 TO 255
CASE ELSE
ENDSELECT
--Rob
D'oh...all well, sorry about that. I thought I mixed it up. Can you do "CASE > 4" or just "CASE pw_12 > 4"?
Y!: synsoflife
Unread 14-02-2003, 23:44
The first one is legal (CASE >4). The second is not legal syntax. Here's a good way to thing of the operators: imagine taking the SELECT variable/expression (from SELECT expr) and putting it immediately in front of the thing after CASE. ie
SELECT p1_y
CASE <127
can be thought of as an if with predicate p1_y<127.
Unread 15-02-2003, 08:56
AKA: Eric Hansen
So, SELECT / CASE is just like a easier IF/THEN statement in a way....nifty.
Y!: synsoflife
PBASIC language syntax WizardOfAz Programming 14 30-04-2003 10:23
PBasic 2.5 vs. 2.0 Anthony Kesich Programming 6 09-02-2003 22:06
Broken PBASIC 2.5 Complier? Mike Yan Programming 12 01-02-2003 09:11
RoboEmu 1.09 (supports PBASIC 2.5) rbayer Programming 22 21-01-2003 17:22
PBASIC 2.5 answer from Parallax JasonS Programming 6 07-01-2003 19:21
