Go to Post There is nothing cooler than engineers playing rock music. - Jay Trzaskos [more]
Unread 11-02-2003, 07:51
n[ate]vw wrote:
"You are pretty much limited to 39 bytes/sec using OUTH every loop. "
If you used all the analog inputs for video you could get 7 8-bit bytes / 26ms, or about 40 * 7 * 8 = 2240 bits/sec, or 268 800 bits / 2-min match. You'd need some circuitry to buffer the signal, and present it 7 bytes at a time, though.
You might get a whole video frame per season through, if you get enough practice time in enough regionals.
It might be hard to read you gyro, though.
Which PBASIC Stamp Editor are you using? Carl Owenby Programming 8 16-03-2003 00:44
OS9 PBasic Stamp Editor? Joe Matt Programming 6 16-02-2003 13:43
New Stamp Editor & PBASIC 2.5 Jnadke Programming 8 24-01-2003 07:57
How differnt is basic stamp pbasic from... Adam Y. Programming 7 08-09-2002 17:07
