Go to Post After the norovirus outbreak at VCU, we had our entire team sterilized. Oh, wait, that doesn't sound right... - dlavery [more]
Unread 12-02-2003, 18:34
Yan Wang's Avatar
Yan Wang Yan Wang is offline
Ithaca is Gorges
AKA: John Wayne
FRC #0639 (Code Red Robotics)
Yan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud of
Send a message via ICQ to Yan Wang Send a message via AIM to Yan Wang Send a message via MSN to Yan Wang Send a message via Yahoo to Yan Wang
Rubber for Attaching to Wheels
For the 9" wheels that came with the kit of parts, does anyone know of any great rubber or other synthetic material which can be glued/stapled/screwed/etc onto the wheels in strips? I'm looking for something with grip comparable to that of Skyway wheels.
Code Red Robotics Team 639 Alumnus | www.team639.org
<Patrician|Away> what does your robot do, sam
<bovril> it collects data about the surrounding environment, then discards it and drives into walls
Unread 12-02-2003, 18:41
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Rubber for Attaching to Wheels
I'm not sure if you know this but the 9" ones in the kit ARE Skyway Wheels.
Search McMaster Carr for Incline Conveyor belting. There is also Brecoflex (a catalog came with the manual) You might be able to pick up some other kind of rubber floor matt material perhaps at your LHS (Local Hardware Store)
Keep in mind you don't want too much traction or you won't be able to turn.
Unread 12-02-2003, 20:22
Icebreakers Icebreakers is offline
#0374 (The Icebreakers)
Icebreakers is an unknown quantity at this point
Thumbs up
We've done this for 4 years. If you can have a machinist cut the existing tread off the wheels to make their surface flat, then screw on conveyor belting , you get GREAT traction. Yes, you can't steer as well if using tank- type steerring, but it's not been a true problem.
Good luck!
GO TEAMS!
Unread 12-02-2003, 21:06
Jeremy_Mc's Avatar
Jeremy_Mc Jeremy_Mc is offline
GitHubber
Jeremy_Mc will become famous soon enoughJeremy_Mc will become famous soon enough
neoprene.
'nuff said.
soft rubber with major traction..
*jeremy
GitHub - Collaborate on code, documentation, etc. - http://github.com
What do you use for wheels? Andrew Technical Discussion 36 08-01-2004 10:20
Adhesive, Brecoflex, Rubber, and M17 Madison Technical Discussion 14 09-01-2003 10:57
Lots of Wheels and F = u x N archiver 2001 17 23-06-2002 23:37
Skyway wheels w/o bearings ahecht Technical Discussion 4 22-01-2002 01:25
