looking at through the parallax site, i found something about the multi bank code. and from the way i read it it seems you need to have a selector defining which band to select code from. as i had been saying in the meetings that we probably need to tell the chip which bank to read the code from. so if we bridge the pins to select the code and it works, i'm going to be all like "I TOLD YOU SO" and such.
~Mr. Ivey |
| The problem with scouting... | archiver | 2001 | 10 | 23-06-2002 23:49 |
| control system programming | archiver | 2000 | 17 | 23-06-2002 22:14 |
| programming problem | gthakore | Programming | 16 | 20-04-2002 12:21 |
| Major problem with chipphua motors | aka Scott White | Motors | 18 | 19-03-2002 19:44 |
| Error found in programming for the pump and pressure switch | sjharobotics | Programming | 4 | 06-02-2002 17:46 |
