Go to Post It really is disconcerting to hear those chains rattling above your head. I think their effect was psychological more than anything else. - Greg Marra [more]
Unread 14-02-2003, 23:35
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
Originally posted by Raven_Writer
Wasn't there supposed to be syntax highlight? I looked through everything, but nothing for highlighting. I also need a little bit of help. I shouldn't be asking this since I've done a comparision between the syntax, but how is switch used?
Parallax has said from the beginning that the alpha/beta versions won't have syntax highlighting but the final version will.
There is no "switch" command. There is a SELECT...CASE...ENDSELECT structure, which does the same thing. Ie:
SELECT counter
CASE 0 TO 100
'do stuff
CASE 101 TO 200
'do other stuff
CASE 201 TO 255
'do even more other stuff
CASE ELSE
'stuff to do if none of the previous cases match
ENDSELECT
There's other things you can put after CASE also (such as a single number or an operator and a number (ie >5)), but the above code is the basics.
--Rob
PBASIC language syntax WizardOfAz Programming 14 30-04-2003 10:23
PBasic 2.5 vs. 2.0 Anthony Kesich Programming 6 09-02-2003 22:06
Broken PBASIC 2.5 Complier? Mike Yan Programming 12 01-02-2003 09:11
RoboEmu 1.09 (supports PBASIC 2.5) rbayer Programming 22 21-01-2003 17:22
PBASIC 2.5 answer from Parallax JasonS Programming 6 07-01-2003 19:21
