Go to Post I've worked with space based navigation and lever arms and planes and Kalman filters. .. and I have never, ever once considered looking up to navigate. - purduephotog [more]
Unread 10-01-2002, 19:26
Brian_Lim's Avatar
Brian_Lim Brian_Lim is offline
#0907 (EY Cybernetics)
Brian_Lim is an unknown quantity at this point
Send a message via ICQ to Brian_Lim Send a message via Yahoo to Brian_Lim
Technical Questions, Rules
About the wheels -- I heard an idea that you could use gears as wheels. Any amount, any size of gear means you can use any size of wheels, as long as they are "gears"? Don't need to order skyway wheels or make them, just use gears?
What is the criterion for wheels? What is a wheel, what isn't, etc?
Traction -- our team has figured out how to get enough power to push the heavy goal using something called a planetary gear system (don't ask me, I don't know : ). How are you guys dealing with traction? We had an idea to use sandpaper. Using sandpaper as some sort of "belt" -- what is a "belt"?
What is the criterion for a belt? What is a belt? Or maybe treads would be a better word. What are treads?
For the motors, is it possible to use ANY 12 VDC motor? What is the criterion for "Drill Motor", which is 12 V?
Thanks for all the help. Don't kill me if you see this message twice, someone called Martin is posting for our team too.
Brian
907
Unread 10-01-2002, 19:47
Brian_Lim's Avatar
Lightbulb Additional Thoughts
Additional Thoughts
The way our team has been talking with help from our coaches is that pushing the goals isn't such an easy job. I heard that someone read on a post that the goals vary from 160-180 lbs. If your robot is 130 lbs, then that would be a considerable weight to push?
One of the problems we discussed was traction. Is traction such a big problem for you veterans that you are considering? It is certainly for our team, since we thought that moving 180 lbs on carpet was nearly impossible.
Of course nothing is impossible. Did you guys need to move those goals last year? I'm under the impression that you didn't, because the pictures of the robots look like they're so lightweight and fast, ball throwing being important.
Brian
907
Unread 10-01-2002, 21:52
Wayne Doenges's Avatar
Wayne Doenges Wayne Doenges is offline
We Build Robots......and Careers
AKA: Warthog
FRC #1501 (Team T.H.R.U.S.T.)
Wayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond repute
Hi Brian
Last year our robot was able to pull a stretcher, w/dead robot, up and over the teeter totter. That's ruffly 180 lbs. All we had was drill motors and groved 8" wheelchair wheels.
Our robot weighed 129.999 lbs
Wayne Doenges
We Build Robots and Careers
World's - #1 seeded in Archimedes, WON Archimedes and made it to Einstein
2016 NC District - Guilford County. #13 seeded, Finalist. Won Quality award.
IN District - Tippecanoe. #4 seeded. Won Innovation in Control award.
IN District - Perry Meridian. #3 seeded. Finalist. Won Excellence in Engineering award.
IN District - State Championship. #1 seeded. Finalist. Won Excellence inn Engineering award.
Unread 11-01-2002, 12:27
Keithicus Keithicus is offline
#0920 (Lancers)
Keithicus is an unknown quantity at this point
Brian,
Treads are like what you'd see on a tank. Go to the gallery on this site and look for MOE from last years competition. They had a nice tread design. The only motors you can use are the ones provided in the kit. Belts are like timing belts or v-belts like you would see on a car or on some drill presses. The guidelines for belts are listed in the additional hardware. Pretty much anything goes. Try the technical forum. There are a lot of good posts about treads/traction and drive systems in general. Also, look through the white pages, they have some good documents on drive design.
Unread 11-01-2002, 12:33
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
I think that you'll find quite a few robots who successfully move the goals... It's not THAT hard, 180 lbs is a big deal, but these goals are on wheels... I think the problem is not going to be moving them, but maneuvering with them... hats off to the team who can dodge other robots while holding/carrying 2 goals...
Unread 11-01-2002, 13:12
bigqueue bigqueue is offline
#0811 (A.R.C.)
bigqueue will become famous soon enough
Send a message via AIM to bigqueue Send a message via Yahoo to bigqueue
Dodge them? Yikes.....not only will that whole load be a heavy one.....but you will present quite a large target when see broadside!
Do you suppose there will be many "2 goal controlling" robots?
-Quentin
Team 4987: Megarams
Unread 11-01-2002, 14:09
JVN JVN is offline
@JohnVNeun
I think there will be a significant amount yes...
It's just a logical step up from last year's robots. Just beef up the tranny and drive...
Time for new rules! archiver 2001 11 24-06-2002 02:01
Full list of teams & competitions archiver 2001 14 24-06-2002 00:52
rules questions... archiver 2001 5 23-06-2002 22:40
Questions on rules nick reynolds Rules/Strategy 1 08-01-2002 01:02
Questions about rules ahecht Rules/Strategy 9 07-01-2002 22:45
