Go to Post Know that CD is a safe environment to learn to talk with a foot in your mouth. - Andrew Schreiber [more]
Unread 16-02-2003, 04:28
Relay o/p are indeed 0V or 5V ! Connecting a relay o/p pin, either W/Y or R, to a digital input pin will indeed give you control of those LEDs.
I relied on the diagram IFI posted, showing the gate with 10k pullup to voltage.
BTW, a 2002 RC input switched the switch LED on the OI at 1V< Vin < 2V, so it is not a CMOS (4000 series or 74HCMOS) compatible input, unless IFI used 3V logic, and against that, the open circuit voltage of the pin is 5V. It could still be 74HCTxxx compatible.
How much planning goes into your robot? Jnadke General Forum 41 29-01-2006 21:29
serious problem found - robot controller resets when jarred! KenWittlief Electrical 23 19-03-2003 13:30
Robot Digital Input Mike Norton Technical Discussion 5 16-01-2003 14:31
WASH Palm scouting at the Championship Mike Soukup Scouting 2 19-04-2002 15:14
about how Drive Train push the robot... shouldn't the force accelerate the robot? Ken Leung Technical Discussion 12 26-11-2001 09:39
