Go to Post You can't derail a thread that had no "rails" to begin with. - bkahl [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 21-01-2003, 11:52
chellyzee93's Avatar
chellyzee93 chellyzee93 is offline
Schuff Rocks my Socks :)
AKA: Michelle Zimmer
#0093 (NEW Apple Corps)
Team Role: Student
chellyzee93 has a spectacular aura aboutchellyzee93 has a spectacular aura about
Send a message via AIM to chellyzee93 Send a message via Yahoo to chellyzee93
Who has used pneumatic wheels?
We're thinking about using pneumatic wheels this year on our robot. We don't have much experiance with them. Any help is greatly appreciated. Any problems with them? Any significant advantages? Thank you.
Team #93 New Apple Corps
2004 Xerox Creativity Award
2004 St. Louis Regional- 5th Seed
Just waiting for that second wind to kick in
-Chell
Unread 22-01-2003, 11:39
Element945 Element945 is offline
#0945 (Element 945)
Element945 is an unknown quantity at this point
pros
traction
softer
biger
suspension
cons
better then other whels no real conspension
"We haven't failed, we just found 10 thousand ways it doesn't work." T.E.
Element 945
Paragon (A.K.A. The Hulk)
Unread 16-02-2003, 10:41
SiliconKnight's Avatar
SiliconKnight SiliconKnight is offline
#0824 (SWAT Robotics)
SiliconKnight is an unknown quantity at this point
Send a message via ICQ to SiliconKnight Send a message via AIM to SiliconKnight Send a message via Yahoo to SiliconKnight
Re: Who has used pneumatic wheels?
We used them last year. They are pretty grippy, and the biggest advantage is because the wheels deform to take the weight, it is a bit more forgiving if you aren't lined up perfectly in the vertical direction, all the wheels will still contact, and you'll get a decent contact patch.
If you are using the sprocket driven hubs, I'd recommend that you put about 2-4 oz of slime (tm) into the inner tube before you inflate them. I've been using slime in my mountain bike(s) for the past 10 years, and can count on 1 hand the amount of times I've had a flat tyre. Once the hubs go on it's dang near impossible to pump the tubes back up, so tire sealant in the tubes to guard against slow leaks (which *will* happen) is a worthy investment. Go to your friendly local bike store for slime, it's a green goop that they sell in a tall plastic bottle.
Happy chips,
-=- Terence
Terence Tak-Shing Tam <ttstam@u.washington.edu>
Engineering Team Captain, SWAT Robotics
http://www.swatrobotics.org
Unread 16-02-2003, 11:49
BBFIRSTCHICK's Avatar
BBFIRSTCHICK BBFIRSTCHICK is offline
Someone find me a FIRST team
AKA: Adriana
#1077 (was: All Stars)
BBFIRSTCHICK is on a distinguished road
Send a message via AIM to BBFIRSTCHICK
We are using them this year, amazing wheels...amazing traction. Just make sure when you are drilling around the area where the wheels are located you dont send the drill bit flying into the wheel. A teammate of mine did that
Team 59 "Ramtech": 2000-2002
Nationals 2001: Galileo Division Champions, National Semi-Finalist
Team 1077 "All Stars": 2002-????
Semi-Finalist, Peachtree Regional 2003 (507 and 356 Rock!)
What do you use for wheels? Andrew Technical Discussion 36 08-01-2004 10:20
Lots of Wheels and F = u x N archiver 2001 17 23-06-2002 23:37
Good or bad: back wheels coming off the ground Gui Cavalcanti Technical Discussion 2 17-03-2002 22:09
Skyway wheels w/o bearings ahecht Technical Discussion 4 22-01-2002 01:25
