In our design, we stuck the light on the top of an arm mechanism that uses a pivot action to move up and down. This means the light will vary between +\- 30 degrees depending on the position of this arm. This is actually the most visible spot for it, because you can see the entire light from 360 degrees around...From what I read and what I want to understand, this is legal becuase the light is pointing downward to most of an extent (I consider it to move past downward at 45 degrees) and there is an unobstructed view of it.
Which brings to mind...we tested the light and does it seem weak to anyone else? Last years was a lot brighter compared to this years... |
| Please...no more steenkin' light! | Andrew | General Forum | 37 | 17-04-2003 23:06 |
| What color light is better on your robot | Rob Colatutto | General Forum | 24 | 11-09-2002 20:33 |
| About the light that need to be seen from four side | archiver | 2000 | 3 | 23-06-2002 23:01 |
| Important info about light | Jay Lundy | Technical Discussion | 10 | 12-04-2002 11:37 |
| How many posters does it take to change a lightbulb? | Brandon Martus | Chit-Chat | 7 | 22-02-2002 19:48 |
