Go to Post Seems decretive bumpers are the new rage now. I couldn't stand making them once, never mind twice. - Gregor [more]
Unread 19-02-2003, 00:59
EbonySeraphim EbonySeraphim is offline
EbonySeraphim is an unknown quantity at this point
Send a message via AIM to EbonySeraphim
(I do argue religiously)
What do you mean by "registering for 10 or more loops?" I assume that you mean both sensors are on for ten loops in a row. The problem is that on the ramp, the sensors will be on and off erratically(or so I think). How will your code distinguish this from actual line tracking data? On a frame by frame input/process loop, you can't look at the big picture. The robot only knows what happening in the current time.
I think I misread your top of the ramp notion though. The top of the ramp that is white I guess could easily be determined by that condition you stated. It's being on the incline that is the problem. The line won't get you all the way to the top, and it's near impossible to be sure that you're on the ramp. So you can't even tell your robot to go straight once you aren't tracking the line.
Ogun's Laughter is No Joke!!!
autonomous mode problem on field Chris_C Programming 17 26-03-2003 19:11
Autonomous Code From Experience EbonySeraphim Programming 7 14-03-2003 21:56
Autonomous code tutorial miketwalker Programming 2 23-02-2003 12:28
Autonomous code PBoss Programming 7 14-01-2003 15:29
Autonomous Code Adrian Wong Robotics Education and Curriculum 1 18-11-2002 22:34
