Go to Post Ok, so you are going to use a robot to hold all of those rivets together? - gblake [more]
Unread 19-02-2003, 01:43
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
Re: Very Simple
Originally posted by Brian_Lim
Why is having an internal counter unreliable?
Because various things can affect how far your robot travels in the period of the counter. A fully charged battery will cause a robot to travel significantly faster and thus farther in the same amount of time compared to a somewhat depleted battery. If someone sets bins in front of your robot it will probably slow you down and screw up your timing as well. This is a fundamental problem with dead reckoning. Ask anyone who has participated in FIRST Lego League about these problems and I'm sure they'll have a lot to say about it!
autonomous mode problem on field Chris_C Programming 17 26-03-2003 19:11
Autonomous Code From Experience EbonySeraphim Programming 7 14-03-2003 21:56
Autonomous code tutorial miketwalker Programming 2 23-02-2003 12:28
Autonomous code PBoss Programming 7 14-01-2003 15:29
Autonomous Code Adrian Wong Robotics Education and Curriculum 1 18-11-2002 22:34
