Go to Post Your students are my idols. - Al Skierkiewicz [more]
Unread 19-02-2003, 19:40
Adam Y.'s Avatar
Adam Y. Adam Y. is offline
Adam Y.
no team (?????)
Like what sevisehda said in his post, wheels can and probably will slip. Though he did mention a fix for it, the solution is way to complicated and still has a good chance of failure. What if something else makes the current reading shoot up? Your robot will try to correct something that didn't even happen! Also your robot could be slipping while its in place(it hit a wall), or it could just be slipping a little(hits a box), or maybe its just hit something so hard to push, its moving very slowly(and still drawing a lot of current). Those are all cases that a robot has to respond differently too.
Actually I have a solution. Mount the encoder disk onto a free wheel that is not connected to a motor. Now the disk only registers pings when the robot moves(hopefully). Of course this is probably the best way to place an encoder disk but unfournatly it is still not perfect. Of course nothing is perfect.
autonomous mode problem on field Chris_C Programming 17 26-03-2003 19:11
Autonomous Code From Experience EbonySeraphim Programming 7 14-03-2003 21:56
Autonomous code tutorial miketwalker Programming 2 23-02-2003 12:28
Autonomous code PBoss Programming 7 14-01-2003 15:29
Autonomous Code Adrian Wong Robotics Education and Curriculum 1 18-11-2002 22:34
