Go to Post If we can transform our culture to the point where girls swoon over guys as they pull their dremel off their belt and carve some speed holes in a smooth fluid motion, I think FIRST is half way to its goal. When we get the guys to swoon over the girls for their hot moves on the 5-axis, we have won. - EricVanWyk [more]
Unread 11-01-2002, 22:23
s_alaniz s_alaniz is offline
#0057 (Leopards)
s_alaniz is an unknown quantity at this point
Fuses
Actually, ELECTRICALLY SPEAKING, it doesn't matter if you put the negative terminal on the fused side of the panel or the positive terminal on the fused side of the panel. The effect is the same. (OK I could point out Kirchhoff's current law but talk about overkill...)
HOWEVER!!!!
Traditionally we fuse the positive side because so many electrical systems have a negative GROUNDED chasis. F.I.R.S.T. doesn't allow us to connect our chasis to the negative terminal of the battery so it doesn't matter in this case. But in the unlikely event you did have a negative grounded chasis and fused grounds on your circuits... and you accidently short a positive lead to the chasis... BIG TIME SPARKS!
I'd highly recommend sticking with the traditional method and connect the positive battery post to the fused side for two reasons.
1) it's good practice and most engineers assume the fuse goes on the positive side anyway
AND
2) the diagrams F.I.R.S.T. provides shows the positive terminals fused. (Don't upset the robot inspectors at check in time!)
Best Wishes
Steve Alaniz
"What good is technology if you can't abuse it?" - Ted Forth
picture of 40 amps fuse holder and fuse rcubes85 Technical Discussion 1 13-02-2003 16:03
a few minor things... Brandon Martus Announcements 0 03-01-2003 23:39
What else do we want? archiver 2000 63 23-06-2002 23:19
Fuse Panels punarhero Electrical 5 18-02-2002 10:52
