Go to Post Not joining as a freshman was the worst mistake I have ever made. - ProgramLuke [more]
Unread 12-01-2002, 00:00
Patrik Patrik is offline
Patrik is an unknown quantity at this point
Send a message via ICQ to Patrik Send a message via AIM to Patrik
Mirrors have opposite incident angle reflection, so unless the mirror is perpindicular it fails and only then it will be unlikey that the the mirror will be perp. for more than a few fractions of a second and hence the system will not mistake it for the retroreflective tape that is on the goals. I am sure the program will not be ruled by a one or two false readings.
I don't think that the red light will affect the infrared sensor. I admit I haven't tested against this but I am willing to bet that the output is polarized in such a way that it should prevent most false outputs (except for other sensors). I don't think the "Dean and The Crew" would have let sensors that could be affected by the safety lights (these are red remember).
I could believe heavy sunlight would affect it, it has a lot of light in every wavelength. I know some of the lazer tag sets (IR guns and sensors) are affected by sun, but I still have a hard time believing either of the mentioned scenarios would affect the sensors to any great amount.
Patrik
To iterate is human, to recurse, divine. -- Robert Heller
optical sensor majormusic2005 Technical Discussion 1 29-01-2003 07:39
Find any optical sensor in catalogs? GreenDice Programming 1 13-01-2003 18:05
optical sensor archiver 2001 3 24-06-2002 02:55
How do you connect optical sensor? archiver 2001 1 23-06-2002 23:05
range of optical sensors Allie Technical Discussion 1 29-01-2002 09:09
