this will work, but it's kinda a cheapo....
Because you are running a 1-1.333 ohm system means you can't run anything lower then that on it. If your amp his a higher resistance rating, the speakers should be fine.... again, please someone speak up if I am wrong... |
| 60 amp Circuit Breaker Info | archiver | 2001 | 1 | 23-06-2002 22:33 |
| Where can I get 60 Amp Fuses -- that look like 30 Amp Fuses? | Anton Abaya | Chit-Chat | 4 | 12-01-2002 14:09 |
| 45 or 75 amp anderson power products connectors to drill motors? | Andrew Wyatt | Motors | 2 | 20-12-2001 08:00 |
