Go to Post I never cease to be amazed at the creative engineering employed by some teams. - Karthik [more]
Unread 21-02-2003, 17:29
Greg Ross's Avatar
Grammar Curmudgeon
AKA: gwross
FRC #0330 (Beach 'Bots)
Originally posted by Jeff_Rice
What is select used for then?
Select is like a multi-condition IF or a BRANCH.
From the PBASIC 2.5 Documentation:
SELECT…CASE can be used to cleanly replace multiple IF…THEN…ELSE structures. The PBASIC syntax
for SELECT…CASE is ( | denotes mutually-exclusive items ):
SELECT expression
CASE | TCASE ELSE | condition(s)
statement(s)
ENDSELECT
Notes:
• expression can be a variable, a constant or an expression.
• condition can be in the form:
{condition-op} #
-- where condition-op is an optional conditional operator: =, <>, <, >, >= or <=
-- # is a variable, a constant or an expression
or…
# TO #
-- Indicates a range of the first number to the next number, inclusive
-- Conditional operators are not allowed in this form.
• Multiple conditions within the same case can be separated by commas ( , ).
• When a CASE is True, the default function is for the CASE's statement(s) to be executed, then
program execution jumps to the first statement following ENDSELECT.
• TCASE, meaning “Through CASE”, behaves exactly like CASE, except that it causes the previous
CASE (if executed) to continue program execution at the first statement within the TCASE,
instead of jumping to after the ENDSELECT. After execution of the statements within TCASE,
execution jumps to after ENDSELECT, unless followed by another TCASE.
Example:
SELECT irCmd
  CASE 0 TO 3
    HIGH irCmd
  CASE AllOff, Mute
    OutA = %0000
  CASE ELSE
    DEBUG "Bad Command", CR
ENDSELECT
2-week FIRST summer program @ WPI ColleenShaver General Forum 20 31-05-2009 03:02
Fried program slots? Jeff Waegelin Programming 18 19-03-2003 18:08
Ahh! Program trick confusing! archiver 2001 9 24-06-2002 02:26
Credits for FIRST program. archiver 2000 6 24-06-2002 00:16
An invitation for HS Juniors archiver 2000 0 23-06-2002 22:51
