Go to Post Wait - a single message outlining the vast majority of where to find controls stuff? Goodness. What will they think of next. - Tom Line [more]
Unread 23-02-2003, 16:52
JLambert's Avatar
JLambert JLambert is offline
#0151 (Wild Cards)
JLambert is an unknown quantity at this point
Send a message via ICQ to JLambert Send a message via AIM to JLambert Send a message via Yahoo to JLambert
User mode toggling
I'm not sure if anyone would know this, but is there a way (in coding) to make a button my controls (p2_trig for example) toggle the OI display between user mode (u000) and something else like team number (0151)?
Justin Lambert
02-03: Programmer Team #151
Unread 23-02-2003, 18:22
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
Nope. Unfortunately, what is displayed on the OI is controlled by the uP's inside the OI, which aren't accessible from the RC. The only thing you can control is what is displayed while the OI is in user mode and the 9 (if you include basic run) LEDs you have direct control over.
Unread 25-02-2003, 05:47
As stated, you cannot control the OI from your joystick, but you can control what your User Mode displays. Just leave the OI in user_mode, and use "selection buttons" on your console.
vbutton, &c, are aliases for console buttons (OI_swAb.bit#), temp is a scratch pad, byte-size variable. The way this is arranged, if two people want to see different things (volts & direction, say) the first branch gets priority, so they will see voltage in the user window.
program snippet....
if vbutton then show_volts
if dbutton then show_direction
show_amps:
temp = sensor3
goto show_it
show_volts:
temp = battery_volts (=sensor8) * bewitch_factor
goto show_it
show_direction:
temp = gyro_heading.highbyte
show_it:
out8 = temp.bit0
out9 = temp.bit1
out10 = temp.bit2
out11 = temp.bit3
out12 = temp.bit4
out13 = temp.bit5
out14 = temp.bit6
out15 = temp.bit7
...rest of program
Programming Autonomous mode Jared Stofflett Programming 3 11-11-2003 09:32
autonomous mode problem on field Chris_C Programming 17 26-03-2003 19:11
autonomous mode timer Don Programming 6 09-02-2003 22:16
Select button and user mode n[ate]vw Programming 2 20-01-2003 16:33
