Go to Post They truncated our conference title. We are not showing the movie "Finding NEMO" - RoboMom [more]
Unread 27-02-2003, 15:29
pras870's Avatar
pras870 pras870 is offline
AKA: Mike
#0870 (Team Rice)
pras870 can only hope to improve
Send a message via AIM to pras870
The red tread on the tire is simply the timing belt given out by FIRST. As for the cups, a small scratch in the HDPE should not really matter. We even tested this on a surface of our HDPE which was scratched, and it did not effect it at all. The way the cups are designed, the pressure which is generated is spread out evenly over the base of the cup, for more surface area. We locked them down, created a vacuum, and had half our team try to push it horizontally from side to side and front to back, and it would not budge.
Unread 27-02-2003, 15:49
evulish's Avatar
evulish evulish is offline
1010100
AKA: Grant Harding
#0084 (WATTNESS (bot: Chuck))
evulish is just really niceevulish is just really niceevulish is just really niceevulish is just really nice
Send a message via AIM to evulish
What about dirt on the HDPE...I think that was our teams concern with suction cups (and the pneumatic resources it would use)...the only time I have seen FIRST take care of the field is when the carpet gets unwound. I really doubt they'll be shining the HDPE after every matching.
I'm a professional web developer. I'm good with PHP, Perl, Java/JSP, some RoR, XML, Javascript (AJAX as well), (x)HTML, CSS, etc.. Validated code is good; fully cross-browser code is better (you comply to your users and the software they use, not the other way around. Sorry!)
Unread 27-02-2003, 15:52
Rob Colatutto's Avatar
Rob Colatutto Rob Colatutto is offline
Roboticsrob
FTC #10092 (Green.Griffins;)
Rob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to behold
i;d like to know how dirt is going to get on the hdpe..... i'd imagine they make the feild reseters clean thier shoes before going out because that could cause a lot to the rug too
Follow me on twitter @roboticsrob and my FTC team @griffins10092
Unread 27-02-2003, 16:24
Rook's Avatar
Rook Rook is offline
#0267 (The Demolition Squad)
Rook is an unknown quantity at this point
Ground metal and rubber, dust, grease from chains, just to name a few things that can get on the HDPE. The top of our practice ramp has some hefty gauges in it, not just fine scratching. In testing our bot, we put it through some rigorous drills and hit some of the old bots we had sitting on top pretty hard. The colisions often resulted in the old bots getting knocked around and the ramp took a licking. We maybe wrong that the HDPE may look just fine after each match. Maybe FIRST will even break out a Zamboni and polish it, but it was just too risky for us to take that chance.
Aaahhhhh! The atmosphere! Aaaahhhh!
(Things you might hear a meteor say.)
Unread 27-02-2003, 16:30
pras870's Avatar
AKA: Mike
#0870 (Team Rice)
a little zamboni driven by a midget would be funny to watch, and serve a great purpose
Unread 27-02-2003, 17:32
UlTiMaTeP UlTiMaTeP is offline
UlTiMaTeP will become famous soon enoughUlTiMaTeP will become famous soon enough
I have no doubt that suction cups will hold great. BUT when a bot hits you its not gonna try and pull you up like a potato its gonna try and push you from the side which a suction cup grips straight down.... for example take any suction cup and take somthing flat, stick it on and feel how much force is needed to pull it straight off, then stick it back on and try and slide it, if the surface is flat and smooth the suction will stay intact but you will be able to move it where ever you would like. Which is exactly what is going to happen at KOH
Hows my searching? Call 1-800-Green-Dots
Unread 27-02-2003, 18:15
Rook's Avatar
This picture
Moving Glass
Should put away any debate on suction cups. The full weight of the glass pane is being held by the suction cups and its on it's side. I don't think the worker would stand where he is, if those cups weren't safe.
Unread 27-02-2003, 18:16
Matt Reiland's Avatar
'The' drive behind the drive
I have no doubt that there are suction cups that can support huge side loads on them. My Mitsubishi Big Screen was carried into the house with 2 suction cups vertically on each side and they didn't slip. The key here is that it was on a 'prefectly' smooth surface (Glossed Burlwood). People out there that are talking about how glass panels are lifted like this are right, BUT.......... once there are small scratches in the plastic where air can leak past the rubber, your suction is gone it is not the same as glass after the first few pushing matches up there.
Unread 27-02-2003, 18:27
Rook's Avatar
I agree
Unread 27-02-2003, 18:41
Katie Reynolds Katie Reynolds is offline
no team (NEW Apple Corps)
Katie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond repute
Send a message via AIM to Katie Reynolds Send a message via Yahoo to Katie Reynolds
My sentiments, exactly.
- Katie
Team #93 - NEW Apple Corps
Student - 2001-2004
Team #857 - Superior Roboworks
Mentor - 2006-2009
Unread 27-02-2003, 18:47
OneAngryDaisy OneAngryDaisy is offline
not on CD enough...
OneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of light
Originally posted by Cory
wow...those things are humongous.
Cory
If you think those are humongous, you should catch the cup on team 1218 from nearby here in Chesnut Hill- those guys have one enormous cup mounted right in the center of their robot.. seemed to work pretty well too..
WakeZero WakeZero is offline
FIRST-a-holic Strategist
#1011 (CRUSH)
WakeZero will become famous soon enough
Send a message via AIM to WakeZero Send a message via Yahoo to WakeZero
Relax people, only a few more weeks and will we find out for sure
2004 Arizona Regional -- Semifinalist
2003 NAT Galileo Division -- Highest Seeded Rookie (20th)
2003 NAT Galileo Division -- 100% Autonomous Completion (7 for 7)
2003 Arizona Regional -- Rookie All-Star Award
2003 Arizona Regional -- Quarterfinalist
Alumni on Team 64, The Gila Monsters
College Mentor/Founder of Team 1011, CRUSH
Unread 27-02-2003, 19:02
soezgg soezgg is offline
Senior Member
AKA: Harry Miller
#0639 (The Rude Awakening)
soezgg can only hope to improve
Send a message via AIM to soezgg Send a message via Yahoo to soezgg
well, there are basically 2 ways to use a suction cup.
1: Put it on the ground and suck all the air out of it so it attatches
2: Push down on it and have all the air go out of it creating suction.
the first way is reverseable
the second way is pretty good if you do it right.
admittedly, it is a good strategy for a koth bot, whether it works or not.
good luck.
Unread 27-02-2003, 19:12
Clark Gilbert's Avatar
Clark Gilbert Clark Gilbert is offline
Clark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond repute
Hmmm
There is another way...
Force it down, and then pull it up.
I've done some research on the internet and there are a ton of suction cups out there, (even rectange shaped). It should be really interesting what teams use this year and how they use them.
Purdue Alumni
Cummins, Inc.
Unread 27-02-2003, 20:12
evulish's Avatar
1010100
AKA: Grant Harding
The suction cup we had prototyped was made out of a circlular peice of aluminum with a groove in the bottom where a latex O-ring fit. It worked pretty well...untill we stratched up the surface a bit. Still, it wasn't very much for the resources it would use (like 2 of our cylinders) If anyone can make it hold and stay...that's where my money is going. Ohh...and that suction cup sticks to faces...not stomachs. Not that I know this personally or anything.
The Death of FIRST Anton Abaya General Forum 23 03-05-2006 17:18
pic: Team 870 Wiring Nightmare CD47-Bot Robot Showcase 15 02-03-2003 21:46
The 2003 Index of team's post about their robot... Ken Leung Robot Showcase 4 28-02-2003 00:18
pic: Team 870 Front Drive Train CD47-Bot Robot Showcase 4 27-02-2003 15:23
pic: Team 870 Rear Drive Train CD47-Bot Robot Showcase 2 27-02-2003 00:22
