Go to Post Seats are seats, we're all watching the same thing. - katiyeh07 [more]
Unread 01-03-2003, 17:58
Gui Cavalcanti's Avatar
Gui Cavalcanti Gui Cavalcanti is offline
Robogeek
Gui Cavalcanti is a name known to allGui Cavalcanti is a name known to allGui Cavalcanti is a name known to allGui Cavalcanti is a name known to allGui Cavalcanti is a name known to allGui Cavalcanti is a name known to all
Send a message via AIM to Gui Cavalcanti
Optical Sensors -> Edu-Bot
I found out how, without an external power source. Apparently the optical sensors run fine on 7.6 volts.
I did the following:
I attached the brown wires (+) to the positive wire of the Edu-RC on a parallel circuit. I then attached the white wire wires to the digital input pins on the board, and connected the blue wires to the digital ground pins on the board, and it works perfectly.
The only issue is that the optical sensors turn on before the robot does - when you plug the battery into the board, the circuit is completes and the optical sensors turn on, so you better not leave the battery plugged in. Oh, and the optical sensors tend to eat up the Edu-Bots batteries in about 15-20 minutes, if left constantly on.
Cool, huh? None of that external battery stuff
Gui Cavalcanti
All-Purpose College Mentor with a Mechanical Specialty
Franklin W. Olin College of Engineering, Class of 2008
optical sensors majormusic2005 Electrical 5 11-03-2003 21:32
Optical sensors with EduBot Gui Cavalcanti Robotics Education and Curriculum 5 02-03-2003 10:05
Q&A Discuss: optical sensors CD47-Bot Extra Discussion 0 15-02-2003 22:58
optical sensors acting strangely rosebud Electrical 10 03-02-2003 00:29
EDUbot Sensors marlon_jbt Robotics Education and Curriculum 11 19-12-2002 13:38
