Go to Post Ah, this sounds like a sitcom whose pilot I should write and send to NBC - "Life With Lavery". There's a lot of eating, several practical jokes, and lots of bad hair. - Amanda Morrison [more]
Unread 03-03-2003, 15:54
Matt Reiland's Avatar
'The' drive behind the drive
From the Spike Manual for RED
Table 1: Spike Red P-BASIC software control, Spike output, Motor function
INPUTS OUTPUTS
Fwd Rev M+ M- Indicator Motor Function
0 0 +12v +12v Orange OFF / Brake Condition (default)
1 0 +12v GND Green Motor rotates in one direction
0 1 GND +12v Red Motor rotates in opposite direction
1 1 GND GND Off OFF / Brake Condition
It appears that with no PWM signal 12V would be available at both terminals, so unless you put the pump to only one terminal and the other side to the ground, it shouldn't have worked on the RED spike either. (No voltage difference between Black & red on the pump)
I think the intention of the Control System is not to have any outputs functional when the Control System is Disabled
Thanks 968 and 294 and last match LA sanddrag Regional Competitions 5 16-04-2003 17:15
How should FIRST Replay a match Matt Reiland Rules/Strategy 4 09-03-2003 11:11
Sound Levels Measured at the Nationals archiver 1999 8 23-06-2002 22:47
Thanks - Wild Stang - What a match!!!!!! archiver 1999 1 23-06-2002 22:15
Pneumatics pump allowed on robot? bigqueue Pneumatics 5 06-01-2002 12:30
