Go to Post Perhaps we should just have signs put up that say "Please remove your head and tail before entering". - Molten [more]
  #61   Spotlight this post!
Unread 03-03-2003, 23:12
Dima Dima is offline
Dima is just really niceDima is just really niceDima is just really niceDima is just really niceDima is just really nice
Send a message via AIM to Dima
andy!
i look at update 4 and it seems to me that those rules apply only to the robot currently on the field.
...meh doesn't matter if the need is there you can always swap stuff.
P.S. if there a chanse you could come by Silicone Valley Regional with that robot?
  #62   Spotlight this post!
Unread 03-03-2003, 23:19
nickma nickma is offline
#0229 (Division by zero)
nickma is an unknown quantity at this point
Send a message via AIM to nickma
Its all your fault
Thanks to you guys my plans for getting work today went out the window. My afternoon plans where to complete the 3 days of school work I would be missing in order to attend BAE but that went out the window when I saw the new 45 drive. I just had to stare at it for sometime to get an idea on what it was and appreciate what it did.
Again my hat goes off to you, as another big stride in drive systems is achieved this year.
Congrates.
Nicholas Malatesta
Clarkson University
03'-?? Team 229
"Division By Zero"
01'-02' Team 190
  #63   Spotlight this post!
Unread 03-03-2003, 23:27
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
Re: Re: more explainations
Originally posted by M. Krass
As the ball's forward rotation is tied to the omniwheels rotation since they're in powered by the same gearbox, I was wondering how you accounted for any imbalance in losses that might exist. After all, if there are more losses on the ball than there are in the omnwheel, wouldn't it spin slower? ...and then, wouldn't it just be dragging and do nothing to "power" the robot?
Does that make more sense?
I really don't know. We have no efforts in evaluation yet. Our prototype had casters, not extra omni-drive wheels. Koors is currently on a mission trip to Hati... when he gets back, he may be able to explain this better than I can.
I see the omniwheel as a power boost, and it only helps the ball drive go forward and back with another contact point.
For instance, when the ball hits the ramp grating, the omniwheel gives the frame more power to push up the ramp. Once the robot is level on the ramp again, then all 4 points of contact are again propelling the 'bot.
There is a slight speed imbalance between the balls and the omniwheels... we are not sure how this affects performance. If the speeds/losses were better matched, I am sure that it would run a bit better. At it's current setup, it does run pretty well and I don't think that we are seeing the "stall" problem that you are describing.
Andy B.
  #64   Spotlight this post!
Unread 04-03-2003, 03:09
Tony's Avatar
Tony Tony is offline
#0111 (Wildstang)
Tony is an unknown quantity at this point
Send a message via AIM to Tony
Words do not do the TechnoKats justice.
Years past, you've ALWAYS been one of my favorite robots. My favorite robot of **ALL** time was your Huge Freakin' Arm of 99 (TKO). That thing could destroy anything in its path.
Now you throw TWO beauties at me to choose from.
Question: My memory is hazy, but the arm on Mighty Mouse brings back memories of the Huge Freakin' Arm of 99. Are there many//any similarities there?
And since there are a number of people that seem to be confused and seem to believe that this is the post where you go to shamelessly plug yourself and your team and your personal 'wondrous' ideas you didn't have the balls to run with (like the TechnoKats did) :
This thread belongs to the TechnoKats.
Fear them.
EXAMPLE OF WHAT DOES BELONG HERE:
TechnoKats, you guys are astounding. I will spend as much time as possible in your pit at Midwest gaping in dumb awe.
You guys and what you've done this year is everything FIRST is supposed to be about.
I can only pray to once again see the wonderful sight of 45 and 111 side by side.
See you at Midwest.
Rock on.
____________________________
i'm your zero
You are Neo
You display a perfect fusion of heroism and compassion.
  #65   Spotlight this post!
Unread 04-03-2003, 04:45
FotoPlasma FotoPlasma is offline
FotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond repute
Send a message via AIM to FotoPlasma
Mad props to 45.
This has to be the most interesting concept turned into reality that I have ever seen.
I'm going to need to see video of this thing in action.
Keep up the great work. And that goes for everyone.
<edit>
Oh, one more thing... I want to see the code for driving this thing...
</edit>
I played hacky sack with Andy Baker.
2001-2004: Team 258, The Sea Dawgs
2005: Team 1693, The Robo Lobos
  #66   Spotlight this post!
Unread 04-03-2003, 13:38
Steven Carmain Steven Carmain is offline
Bit Twiddler
FRC #2832
Steven Carmain will become famous soon enough
The program was thrown together at the last minute. The program is just a simple tank drive code with 2 sticks, and if you move the right stick left and right, it gives you sideways movement
2017 - Team 2832 Mentor
2016 - Team 6013 Mentor
2002-05 - Team 45 Software/Electrical
A robot is like a campfire: it takes a while to bulid it, and then everyone surounds it!
A world without standards is chaos. A world with standards is chaos.
  #67   Spotlight this post!
Unread 04-03-2003, 17:41
Dr. Bob Dr. Bob is offline
#0233 (Roccobot)
Dr. Bob is an unknown quantity at this point
So as everyone has said. The Ball drive system is real impressive. Must be awsome on the feild. But thats just the base. How much can that little claw really do?
|+ - - a b|
  #68   Spotlight this post!
Unread 04-03-2003, 18:54
Clark Gilbert's Avatar
Clark Gilbert Clark Gilbert is offline
Clark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond repute
Arm
The arm operates just like any other arm (it's similar to the 1999 arm with less joints). It's meant to be a stack destroyer and that's it. I'm guessing it could try to remove 1 tote to lower the multiplier or it can swing and wipe out 1/2 or all of the stack. For a sure method of removing the whole stack it can grab under the lip of the bottom tote with the lexan attachment at the end. Once it's under the lip it lifts and topples the stack.
Purdue Alumni
Cummins, Inc.
  #69   Spotlight this post!
Unread 04-03-2003, 20:43
gsensel gsensel is offline
AKA: Geoff Sensel
gsensel will become famous soon enough
Send a message via AIM to gsensel Send a message via Yahoo to gsensel
As a past member in the team I am impressed with what I see in this and the other parts of the team.
Geoff Sensel
Andy Baker used me as a positve example at nationals in 2004!!!!!(Now who is the role model DJ????)
I was looking to start a team for my college for next year, but they got hooked up with a local JR High school doing BEST Robotics competition. Has anyone heard of this?
I was previously on the Technokats from 1998- 2002.
  #70   Spotlight this post!
Unread 05-03-2003, 14:48
soezgg soezgg is offline
Senior Member
AKA: Harry Miller
#0639 (The Rude Awakening)
soezgg can only hope to improve
Send a message via AIM to soezgg Send a message via Yahoo to soezgg
i agree, very cool system, even if you dont get to use it.
my question: why would you patent it, and what purpose would that serve?
  #71   Spotlight this post!
Unread 05-03-2003, 15:19
Bit Twiddler
FRC #2832
As it says earlier, the reason we patented it was so companys like Segway take our design and make a one ball Segway. It just stops companys from making money on our design.
  #72   Spotlight this post!
Unread 05-03-2003, 15:24
Beast314's Avatar
Beast314 Beast314 is offline
Team #171 President
AKA: Jeff Mathes
#0171 (Hardcore Engineers)
Beast314 is on a distinguished road
Send a message via AIM to Beast314 Send a message via Yahoo to Beast314
I must say I don't know if we'll see a ball driven Segway, but it's never a bad idea to patent ideas. I only wish I would have done that with ideas I've had. I can't wait the less than 24 hours to check out you're bots.
Jeff Mathes
Team #171 President
Alumni of Team #93
  #73   Spotlight this post!
Unread 30-03-2003, 10:23
Gadget470's Avatar
Gadget470 Gadget470 is offline
A Fire Outside
AKA: Brandon Joerges
no team (Alpha Omega)
Gadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the rough
Send a message via ICQ to Gadget470 Send a message via AIM to Gadget470
Sorry to bring up a dead thread but I think it's appropriate.
Originally posted by JosephM
While I think this is great and very cool, I just wonder if this years task was so simple that we can afford such lavash things. What about other teams who can barely move? Were the TechnoCats right to spluge on their drive while many teams still don't move?
Just a question.
Well Joseph, as was witnessed this weekend at the Midwest Regional. The technokats splurging provided another team which couldn't move a chance to play.
The technokats would have done it anyways, as they already had prototypes made. They just needed to start it's build post-kickoff if they were to want to compete with it.
I feel that if a team can afford it and it's of use to someone less fortunate, they should definitly build or use whatever it may be. The teams who blow thousands just so they have something neat.. well I don't like seeing those.
The technokat's once again showed the meaning of FIRST. An Ispiring new development in the Science and Technology field, and backing it with Gracious Professionalism.
  #74   Spotlight this post!
Unread 30-03-2003, 11:48
Austin's Avatar
Austin Austin is offline
Go TechnoKats!
FRC #0045 (TechnoKats Robotics Team)
Austin is a name known to allAustin is a name known to allAustin is a name known to allAustin is a name known to allAustin is a name known to allAustin is a name known to all
Send a message via AIM to Austin
Thank you Gadget.
Austin Butler| Mac Addict | Purdue AAE | President, Sigma Gamma Tau | ENS USN/Student Naval Aviator
2002-2005 driver | 2004 Lead Mechanical | 2004-2005 Co-Student Leader | TechnoKats Robotics Team 45
Need a gearbox? Omniwheels? Check out AndyMark.biz
  #75   Spotlight this post!
Unread 30-03-2003, 12:41
OneAngryDaisy OneAngryDaisy is offline
not on CD enough...
OneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of light
I'm dying to see this in action- what team did you Technokats lend this drivetrain to? You sure did deserve that judges award!
pic: TechnoKat Transmission 2003 CD47-Bot Robot Showcase 55 23-07-2003 14:41
pic: Ball Drive Close Up CD47-Bot Robot Showcase 17 04-03-2003 15:23
