Go to Post If you're sore over the vigorous defense teams play, get over it. It happens and will continue to, as the majority of people hope. - AmyPrib [more]
  #61   Spotlight this post!
Unread 05-03-2003, 16:08
DougHogg DougHogg is offline
Robot-A-Holic
FRC #0980 (The ThunderBots)
DougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud of
Re: Top in 2.2 secs
Originally posted by Paul Copioli
We have tested and repeated several times now and we get to the top in an average of 2.2 seconds. Our fastest was 2.0 and our slowest was 2.4 (averaging all the trials). When I say the top I mean contact with the bins. We stopped the time as soon as the robot made bin contact. We have an identical practice bot and are tweaking, because my calculations show we should be at 1.9 seconds. I know what you're thinking, but let me just say this: I used differential equations to model the behavior of our robot on this year's playing field and so far everything except the final time is mapping within a few percent.
-Paul
P.S. - we don't want to be king of the hill, just king of the bins.
I just looked at a picture of your robot. I am amazed that you can get to the bins so fast. How do you avoid tipping over going around the corner?
If we qualify for the championships and meet up with you in Houston, I hope we are on your team.
FIRST Team 980, The ThunderBots
2002: S. California Rookie All Stars
2004: S. California: Regional Champion,
Championship Event: Galileo 2nd seed,
IRI: Competition Winner, Cal Games: Competition Winner
2005: Arizona: 1st seed
Silicon Valley: Regional Champion (Thanks Teams 254 and 22)
S. California: Regional Runners Up (Thanks Teams 22 and 968)
  #62   Spotlight this post!
Unread 05-03-2003, 17:10
Mike Norton's Avatar
Mike Norton Mike Norton is offline
FRC #0061
Rookie Year: 1995
Mike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to all
Originally posted by ahecht
190's robot should be able to reach the top in 3 seconds this year. Control won't be a problem either. I can't say much more than that.
Control won't be a problem? I watched the videos from UTC matches it looks like you need a lot of help. Not once did you make it to the top under the auto mode.
You might make it to the top in 3 seconds but it has not happen yet.
And by the way it looks like if someone puts a bin in front of your robot the robot does not do well.
I see you are a little top heavy. Having a robot be able to flip you now is not a good thing.
  #63   Spotlight this post!
Unread 05-03-2003, 21:00
Tom Schindler's Avatar
Tom Schindler Tom Schindler is offline
Now an AIR Striker....
FRC #0078
Tom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond repute
Send a message via AIM to Tom Schindler
Thanks for the compliments.
Just to let you know, our "INS" was not installed at the UTC scrimmage, we were running off "dead reckoning" - the reason it looked like a bin gave us problems was really because the program was not done correctly.
If you watched all of the UTC matches, you would see that in our final match we were able to successfully get to the top of the ramp under autonomous, in low gear.
If you are going to post something negative about a robot, at least have correct information.
Thanks, looking forward to seeing everyone tomorow at BAE
Tom
  #64   Spotlight this post!
Unread 05-03-2003, 22:02
Willum's Avatar
Willum Willum is offline
#0871 (Robotechs)
Willum is an unknown quantity at this point
Send a message via AIM to Willum
I'm good friends with a member of 190, and as he explained several things not just ins were not in order. they weren't truly topheavy, but their wing mechanism wasn't collapsing as designed. WPI has an excellent robot, and it's fast, however.... I do think that 3 seconds is overestimating yourselves again. Chris said about 5 seconds.
At the UTC scrimmage they took 10-12 seconds in dead reconing, and were the only bot to knock down ~70% of the stack. They were ahead of many teams even then.
871 is in about the same time range of 5 - 5.5 seconds.
Great job guys, i wanna see this INS in action. and how you guys did that after or at houston.
  #65   Spotlight this post!
Unread 06-03-2003, 00:04
Teedoff101 Teedoff101 is offline
#0992 (Oakwood Robotics)
Teedoff101 is an unknown quantity at this point
The bot from Oakwood (Ralph II) should be able to get to the stack in about 1.5 seconds based on previous testing before shipping. We dont have to move so we dont have to be horribly fast. We should be able to knock down about 80% of the boxes if we measured angles correctly. Anyways, hope to see a lot of you at SoCal. Peace.
  #66   Spotlight this post!
Unread 06-03-2003, 09:13
BK36 BK36 is offline
#0716 (WHO's CTEKS)
BK36 is an unknown quantity at this point
Our robot uses dead reckoning and makes it to the top in 3 seconds and can knock about half of the totes into our scoring zone. We were able to see this happen at UTC but our program was not quite finished so we didn't get as many boxes as we had hoped.
How many people are actually able to get the top in under 5 seconds, and are you using line tracking or dead reckoning to get to the top?
  #67   Spotlight this post!
Unread 06-03-2003, 09:20
President, VEX Robotics, Inc.
DougHogg,
It looks like we are top heavy, but in fact 95 lbs (including battery) of our robot is located below 9 inches. The framework above is basically aluminum tubing, with the exception of one motor.
We have steering wheels that control our circle diameter and dynamic wheel speed control to slow down the inside wheels based on steering angle. This reduces the amount of skid that our robot has when cornering.
-Paul
  #68   Spotlight this post!
Unread 07-03-2003, 00:36
soezgg soezgg is offline
Senior Member
AKA: Harry Miller
#0639 (The Rude Awakening)
soezgg can only hope to improve
Send a message via AIM to soezgg Send a message via Yahoo to soezgg
wow, anything under 3 seconds is very impressive
and very useful
my question is, how many autonomous modes work for people?
from what i hear, not very many
  #69   Spotlight this post!
Unread 07-03-2003, 00:48
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
and very useful
We estimate we get there in about 4-5 secs. Our dead reckoning auto mode works perfectly on a scale field (with the correct surfaces) but has not been tested in actual competition. We will know in less than a week.
  #70   Spotlight this post!
Unread 07-03-2003, 17:48
#0716 (WHO's CTEKS)
We have 7 fully functional autonomous modes that have been tested but werent perfect when we shipped due to the lack of a full field to test on. our last one is in its final stages right now but we wont know if it works till next Thursday at the UTC competition.
  #71   Spotlight this post!
Unread 07-03-2003, 20:39
Jeff Waegelin's Avatar
El Jefe de 148
AKA: Midwest Refugee
FRC #0148 (Robowranglers)
So, how are on-the-ramp times looking after the first real day of competition?
Jeff Waegelin
  #72   Spotlight this post!
Unread 08-03-2003, 20:23
David.Cook's Avatar
David.Cook David.Cook is offline
#0384 (Sparky)
David.Cook is an unknown quantity at this point
Send a message via Yahoo to David.Cook
Here is what I can tell you from the NASA/VCU regionals.
We were lucky to have a fairly repeatable dead-reckoning auton mode. We hit the ramp pretty consistently in about 5-6 seconds, although, I must admit that due to the nature of competition I never thought to time it - we had more pressing concerns. Many teams had similar time. Maybe 3-5 were faster that we, and then there was 234 with that incredible arm. (great job 234!!)
[we actually had one match where we hit the stack about a half second after 234 hit the stack with there arm from diagonally across the field - they got more bins than we did from that start]
There are also about 20% of the teams with very slow auton mode, but many were still effective.
If I had to sum up, it was only in the elimination rounds where you really started to see more than two robots hit the stack early in auton mode. Also, it is my opinion (quite the opposite from my original thoughts 6 weeks ago) that getting all the bins early does not correlate with winning the match. There are a multitude of small bots that can push bins around, and many were flying out of the field just due to impact.
We had incredible luck, a great driver, a very tough bot and two remarkable alliance partners (Props to 388 from W. VA and 395 from the Bronx!!!!!!) and we won the finals.
All I can say is strap in tight, it is an incredible game!
Be unrestrained as the wind...
  #73   Spotlight this post!
Unread 08-03-2003, 21:24
Richard Wallace's Avatar
Richard Wallace Richard Wallace is online now
I live for the details.
FRC #3620 (Average Joes)
Beware the Bomb Squad
Most robots at the St Louis regional had ineffective autonomous modes. My team was slightly better than average when our dead reckoning worked correctly, which was less than half the time. When things went well, we hit the wall in about 6 to 7 seconds and took two or three columns over with us.
The fastest robot, by far, was Team 16 Baxter Bomb Squad. They got to the wall in 2 to 3 seconds and took out 3 or 4 columns, consistently match after match.
And then there is 547. Their robot isn't any faster than ours, but if it gets there first, it sends the entire wall to its side. A truly awesome sight.
Richard Wallace
since 2003
  #74   Spotlight this post!
Unread 09-03-2003, 13:22
mjd547 mjd547 is offline
#0547 (F.E.A.R.)
mjd547 is an unknown quantity at this point
Thumbs up
St. Louis was great. thanks to all the teams who helped us the whole way. thanks to team 936 and 476, our final alliance partners who did a great job and should be extremely proud.
we had a very reliable auto. mode. it took about 7 seconds to knock down ALL 29 bins. we knocked them all down 5 out of 8 times during the qualifying rounds. once, team 45 beat us to the hill with a very fast and effective auto. mode. another time, we lost our auto due to our human player not getting back to the mat on time, and once more when our arms didn't deploy, but thanks to cory, our driver, and amy, our operator, we managed to do great and be consistent the whole time. also our backup drivers, kreig and zach did a teriffic job along with our human player Jess, and mentor, nick. over all we were very successful at St. Louis with a final ranking of 9. we also won a gm industrial design award. I would also like to congratulate the winners, team 171 and their alliance partners.
BBS (team 16) had the fastest auto. (about 2- 3 seconds to the top and another 1-2 seconds to knock down over half the boxes), and the fastest bot, with excellent drivers. there are many other teams that did great and many more that helped us out during the competition and we thank them.
~micah
  #75   Spotlight this post!
Unread 09-03-2003, 13:32
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
254 consistently got to the boxes in 2.5-3 sec at Sacramento. There were four or five teams that could consistently get to the top in autonomy. Our robot was much slower to the top than expected, but we made it there right before the human control mode kicked in, setting us up perfectly to hit 2 rows, turn and hit some more. Our linefollowing/gyro autonomy earned us the Delphi Driving Tommorow's Technology award, which made us all extremely happy.
Cory
2001-2004: Team 100
2006-Present: Team 254
2 fast 2 furious mocking picture :) miketwalker Chit-Chat 7 18-06-2003 22:28
need help fast!!! Hubless 1/4 pitch sprockets Travis Covington General Forum 6 03-02-2003 18:44
How fast? archiver 2001 4 23-06-2002 23:59
The Fast and the Furious... II !! Justin 188 Rumor Mill 7 07-06-2002 21:47
How fast will your robot be? Anton Abaya General Forum 18 20-01-2002 22:26
