Go to Post Humility tends to take people places, pompous boasts tend to get people left at home by themselves. - Karthik [more]
Unread 07-03-2003, 23:34
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
Re: Solution
Originally posted by K. Skontrianos
You can't test your controls during autonomous control, because they default to 0/127. Instead you must test any autonomous selection switch in your non-autonomous code and then save this value in a "dummy variable" for the autonomous period.
That's true of the switches that connect to the OI, but the ones on the RC should still work fine. (ie you can't use p1_sw_trig, but you can use rc_sw1).
Programming Autonomous mode Jared Stofflett Programming 3 11-11-2003 09:32
Autonomous mode AntmanIV General Forum 1 17-02-2003 13:30
autonomous mode timer Don Programming 6 09-02-2003 22:16
autonomous mode Stephanie Programming 2 25-01-2003 19:57
autonomous mode? bigwalt Technical Discussion 1 21-01-2003 01:14
