Go to Post It’s not that we don’t have the time to teach first principals; it’s more that we (FIRST) don’t need to. - Jack Jones [more]
Unread 09-03-2003, 01:01
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
I'm not so confident the controller can count for volatge very accurately. We got some numbers that just seemed amazingly low under load sometimes.
If you have only the Chias driving I wouldn't suspect them shorting at all. However, if by some stroke of bad luck you got a defective one, it could be internally shorting or arcing perhaps. Assuming that you have one motor for each side of your bot, run your robot up on blocks (wheels off ground) and listen for a different tone when running each side separately. Slowly advance the control for one side of the drive system and get a feel for when it begins rotating and the sound it makes at different points along the range. Do the same for the other side and listen if there are any major differences in the sound. Certain sounds can indicate things binding or a lot of drag in the system too which can lead to the battery draining quickly. This was a big problem (now corrected) for us this season.
power to the pits Ken Leung Off-Season Events 12 11-05-2003 22:48
URGENT!! Need OI power brick specs for 7AM demo tomorrow!!! kmcclary Electrical 8 10-10-2002 10:56
power supply of control system archiver 2000 5 24-06-2002 00:14
power of globe motor with gear box? Ken Leung Motors 5 21-11-2001 13:43
Max mechanical power of motors, how is it useful? Ken Leung Motors 1 09-11-2001 14:15
