Go to Post Everyone builds their robots uniquely, runs their teams differently, and prefers all kinds of flavors of ice cream. Now, we are seeing that folks vent and react differently to a frustrating situation. ... and that's ok. - Andy Baker [more]
Unread 16-03-2003, 14:10
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
We did some timing measurements like this early in the build season. We used an old robot controller that was out of warranty and took the cover off. We hooked up a logic analyzer probe to the lead of the BASIC Run LED and then toggled this at certain times in software. The BASIC Run LED doesn't go through the input or output processors so it changes as soon as you set it in the BASIC code (this is unlike all other outputs which only change when the output processor decides to change them, which as we discovered can be up to something like 16 milliseconds AFTER the serout command by the Stamp!).
If you have a controller you don't mind taking apart you should be able to recreate this easily, although measuring it with a scope will probably be a little more difficult than with a logic analyzer. If you don't have a controller that you're willing to take apart, you could always hook up a phototransistor or something similar and just tape it down over the LED on the outside of the controller.
time change David Kelly Chit-Chat 14 06-04-2003 23:10
Solution to Timing Loops Steven Carmain Programming 39 10-02-2003 13:33
How long should production time be??? archiver 1999 4 23-06-2002 23:16
Nationals accomodations, etc Caliostro Championship Event 21 21-12-2001 14:31
need help with time zone! Ken Leung General Forum 6 25-06-2001 12:44
