Go to Post We all change, and we need to make sure that we can grow and change together in a positive way. Keep close the people who are capable of doing this with you, and you will surround yourself with the tools for success. - Jaine Perotti [more]
Unread 17-01-2002, 10:14
BillCloyes's Avatar
BillCloyes BillCloyes is offline
#0677 (The WireStrippers)
BillCloyes has a spectacular aura aboutBillCloyes has a spectacular aura aboutBillCloyes has a spectacular aura about
Originally posted by Wayne Doenges
Last year we used drill motors for propulsion. We used servos to shift gears. The problem is you had to be standing still to shift. We had a spring go from the servo arm to the shift lever. The spring acted as a servo saver and wouldn't stall the servo. When the servo arm would swing left/right the spring would pull on the shifter. It worked pretty well.
Wayne Doenges
Could you post some pictures for this spring lever.
Shifting Gears MBosompra Technical Discussion 71 23-07-2004 02:49
Regional & Division winners, did you shift gears or not? DougHogg Technical Discussion 34 02-05-2003 16:10
Helical gears that come with new drill motor Joe P Technical Discussion 4 12-01-2003 11:09
Best source for gears? Smallparts? drivetrain advice wanted! Frank(Aflak) Technical Discussion 11 10-01-2003 17:22
Need help! What kind of gears are we allowed to use?? Randy_Ai Technical Discussion 3 23-01-2002 22:56
