Go to Post And like Woodie told us in his talk, all the bad stuff we anguished over will be replaced by the memories of the achievements and good time we had this year. - Wayne C. [more]
Unread 19-03-2003, 12:02
Clark Gilbert's Avatar
Clark Gilbert Clark Gilbert is offline
Clark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond repute
Check the White Papers
2003 Automated Dead Reckoning Test Code uploaded/authored by Greg McCoy into the Programming
Description:
This drive code is intended for less experienced programmers to get a place to start with the code and start testing on existing robots. This code is based on the old Default code, so it works on all controllers, but will need to be updated or modified to work as competition code. The numbers used to determine distance will change for your robot, so you will have to do some tweaking here. All of this is documented fairly well in the program text. Plug joysticks into ports 1 and 3 on the OI, plug the drive Victors into PWM 1 and PWM 2, and you're set to go! Use the throttle wheel on port 3 to control automatic code on or off.
Update: I've fixed a silly typo that made the last step 7 instead of step 6 as it should be. Sorry about this!
Check it out here!
Purdue Alumni
Cummins, Inc.
2-week FIRST summer program @ WPI ColleenShaver General Forum 20 31-05-2009 03:02
White Paper Discuss: 2003 Automated Dead Reckoning Test Code CD47-Bot Extra Discussion 10 07-09-2005 11:25
Fried program slots? Jeff Waegelin Programming 18 19-03-2003 18:08
Autonomous Mode Strategy Brian48216 Programming 27 23-01-2003 14:47
Ahh! Program trick confusing! archiver 2001 9 24-06-2002 02:26
