Go to Post I think this can be cleared up easily...one of the New Hampshire teams needs to go dumpster diving at FIRST HQ and look for an invoice. - Vaillancourt88 [more]
  #61   Spotlight this post!
Unread 23-03-2003, 20:35
GregT GregT is offline
GregT will become famous soon enough
Send a message via AIM to GregT
What they need to do is write a small little program that does this and assures everything is random and distributed.
If I can do it (http://elmo2.ath.cx/gen/) then surely someone at FIRST or a volenteer could.
Greg
The above was my opinion. I'm wrong a lot. I'm sarcastic a lot. Try not to take me too seriously.
  #62   Spotlight this post!
Unread 23-03-2003, 20:43
Alexander McGee's Avatar
Alexander McGee Alexander McGee is offline
Hoonigan
AKA: Alexander S. McGee
no team (no team)
Alexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond repute
Send a message via AIM to Alexander McGee Send a message via Yahoo to Alexander McGee
PLEASE FIX!!
Ok folks. At GLR, Team 68 was paired with the same team twice, and played against that team twice. This happened with two teams!, so, in all 6 of our matches, we saw the same two robots 8 times. Whaaa??? One would think that programming this wouldnt be terriblly difficult.
More iderations and an "if then" statemenet or something (spare me the correct terms, im not a programmer)
Oh well. I heard that it was being looked into at GLR for the midwest and grandrapids regionals.
-Alexander S. McGee
Intellectual Property Attorney, Mechanical Engineer, Gear-head
  #63   Spotlight this post!
Unread 23-03-2003, 23:09
sevisehda's Avatar
sevisehda sevisehda is offline
sevisehda is an unknown quantity at this point
Send a message via AIM to sevisehda
Greg. I ran the applet and typed in the info of 40 teams 10 matches... It paused for about 10 min luckly i had it in the background. I made a similar prog in java but had it output a 'debug' screen filled with a table that showed who played who. I thought your program was the solution until I ran into the divisable by 4 issue. Regionals don't always have a multiple of 4 number of teams. I'd love to see the source code if your willing to share.
  #64   Spotlight this post!
Unread 23-03-2003, 23:42
I know the divisible by 4 is annoying, I haven't spent the time to work around it.
The zip file I attatched earlier will output info as it works, the applet works on only one thread so it appears to lock up (in truth only the gui is locking up, it is working). My program really has no checking and will continue attempting to find a impossible match list. If you feel it's taking to long try lowering the target or min times between matches (and raising the number of times to play with others).
Like I said, its not a good solution but my program will work if you give it possible constraints and enough time to do its thing.
You don't want to see my source as it is really really poorly written
Greg
  #65   Spotlight this post!
Unread 24-03-2003, 00:36
FRC Key Volunteer Trainer
AKA: CrazyNate
Being the scoring operator at Great Lakes this past weekend, and therefore the one telling the system to generate the matches, I am well aware of this problem. It stems from how the system attempts to maximize the time between matches for a given team(the algorithim used is meant specifically for this.) Unfortunately, this causes a less than perfect distribution, as many have already mentioned. I am currently working on a system which will be submitted to the proper people at FIRST(having worked extensively with the FIRST scoring systems the last few years, I know who these people are) for preliminary testing at the West Michigan Regional(if not sooner), which will do the following:
-ensure that no team has the same alliance partner more than once in 99% of situations(the strange "overlap match" between one set of matches and the next is the only exception).
-Attempt to allow at least 5 matches between 2 matches that any given team competes in(may be changed, the code is really ugly for this part)
For those of you who have seen my discription of the pairings code used for OCCRA this past year, this may all look vaguely familiar...that's because it's based off of the same code. Because of this, my repeat opponent checking logic still stands...there is none. My feeling is that unless both alliance members in the opposing alliance are the same(which is 99% impossible using my pairings code, due to the ally checking), you do not truly have a "repeated opponent" However, the system uses a random number generator, re-initialized at every launch, so if you don't like the # of repeated single team opponents, just run it again and get a different set of values. I'm actually working on final testing and FileMaker integration now, so we'll see what happens...
---UPDATE---
On the first trial run with FileMaker Integration, The statistics I got were as follows:
Max Times paired w/ same team: 1.0
Max Non Unique Allies: 0
Avg Non Unique Allies: 0
Count of Teams with 3 or more ally repeats:0
Max times opposing same team: 2
Max # Non Unique Opponents: 2.0
Avg # Non Unique Opponents: 0.7
Min # Between Matches: 6.0
Avg # Between Matches: 13.7
Max # Between Matches: 33.0
What do you think?
Nate Smith
nsmith@smythsoft.com
  #66   Spotlight this post!
Unread 24-03-2003, 02:01
sevisehda's Avatar
Whats that data show? How many teams? How many rounds? How many rounds total? Otherwise its hard to know if 13.7 rounds is a long or short break. At some regionals teams play 10+ times while at larger ones its 6 matches. And since there always seams to be about 100 matches played then thats an average break of 10 and 13.33 respectively.
  #67   Spotlight this post!
Unread 24-03-2003, 08:18
AKA: CrazyNate
I realized sometime overnight that I had forgotten to include this information, so here it is:
# of Teams: 68
Matches Per Team: 6
Total Matches: 102
Nate Smith
  #68   Spotlight this post!
Unread 24-03-2003, 15:07
Sounds very good.
Hopefully FIRST will decide to use your program (and I see no reason for the not to).
Greg
  #69   Spotlight this post!
Unread 24-03-2003, 15:54
AKA: CrazyNate
Originally posted by GregT
Sounds very good.
Greg
FIRST now has the source as well as a high-level description of its workings, and one of their scoring developers is going to take a look at it probably tomorrow to see if there is a nice way to either tie my program into filemaker, or rewrite the logic directly in FileMaker's scripting language. He seemed very interested in finding a way to use it...it's just a matter now of making it easy to use for those scoring operators who don't want or need to know how everything works under the hood...
Nate Smith
  #70   Spotlight this post!
Unread 24-03-2003, 16:13
AKA: Lars Kamen's Roadie
FRC #0051 (Wings of Fire (on sabbatical))
Match List Stunk
I must say, our match list really sucked (sorry for the harsh words). We had 249 in 3 matches, 560 in 3 matches (we were partners in 2 matches), and 494 in 2 matches. I'm not saying that these teams sucked, but what I mean is that it would be nice to get a little more variety. I would sacrifice a little unpredictability in time-between-matches to have a little more variety in the matchups. I don't care for it when there are 68 teams at a regional and I see one team in half our matches and another team in another half of our matches.
So, pleeeeease Nate, get your program to work and use it for West Michigan. If it works well there, use it at nationals.
-Chris
  #71   Spotlight this post!
Unread 24-03-2003, 17:13
Kris Verdeyen's Avatar
Kris Verdeyen Kris Verdeyen is offline
LSR Emcee/Alamo Game Announcer
FRC #0118 (Robonauts)
Kris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond repute
Don't forget Houston, the LSR. Use it there, too. Although, if you do the math, with 31 teams, the highest number of matches a team could have without repeating one of the three other teams is ten, and we'll probably play at least twelve each, so I'm expecting a lot of repeats.
...Only a few people are awake and they live in a state of constant total amazement. -JP Shanley, Joe vs. the Volcano
  #72   Spotlight this post!
Unread 31-03-2003, 06:35
A_Bud's Avatar
A_Bud A_Bud is offline
#0782 (Kilowattz)
A_Bud is an unknown quantity at this point
My team, 782, was partnered up with Buzz twice. Not that it really matters that much.
-Aaron B.
Team 782
2001-2003 Founding Member
2002 UTC New England's Top Rookie Seed
2003 UTC New England's Top Seed
2003 UTC New England's Regional Winners
2003 UTC New England Xerox Creativity Award
2003-2004 University of Hartford Mentor
  #73   Spotlight this post!
Unread 31-03-2003, 07:17
Matthew W's Avatar
Matthew W Matthew W is offline
Wildstang Alumni
no team (Wildstang)
Matthew W is an unknown quantity at this point
Send a message via AIM to Matthew W
Wildstang had the same team twice in a row in Midwest.
As my programming teacher would say, "don't ever depend on a computer to give you a random number because it cannot pick a random number, it's just making it look random." That is unless you just take that # out so it will never be used again or that any team # can only be picked x times and they get pulled out. To pick random #'s a computer usually runs through a "list" of #'s with set bounds to how many #'s to run or what #'s to run. If you catch it too fast or there is a glitch in the program it can be the same #. I truely think that they should have done it with lottery balls or a hat because that is way more random.
  #74   Spotlight this post!
Unread 31-03-2003, 08:04
slavik slavik is offline
slavik has a little shameless behaviour in the past
Send a message via AIM to slavik
We had to play team 494 the martians (probably the best team there) 3 times! We beat them once (even with a disabled partner
  #75   Spotlight this post!
Unread 31-03-2003, 08:22
Soukup's Avatar
Soukup Soukup is offline
Animation Guru
AKA: David Soukup
Soukup is on a distinguished road
at midwest, we found that we had to be partners with some teams, and then go against them the next round. This happened about 4 times. It was frustrating especially when we'd help teams with robot problems that would be almost done when the match started, but couldn't show up or do anything, And then the next round they were working fine. More importantly, because of the schedule I didn't get to see half of the teams compete, including our ellimination partners team 217. So I hope it a little bit more random and West Michigan.
soukupd_gv@hotmail.com
Team 74 Alumni
2003 Great Lakes, Midwest, and West Michigan Regional Animation Award Winner
Random Pairings??? DragnButt General Forum 11 23-03-2003 11:34
Match List Jack OCCRA 11 03-01-2003 12:33
QUESTION - Random Alliance Pairings archiver 2001 2 24-06-2002 02:03
Sound Levels Measured at the Nationals archiver 1999 8 23-06-2002 22:47
How random is random???? archiver 1999 0 23-06-2002 21:59
