Go to Post The engineer mentors ARE part of the team, equals with the students in every aspect - KenWittlief [more]
Unread 18-01-2002, 14:15
jonnywalk jonnywalk is offline
jonnywalk is an unknown quantity at this point
Send a message via AIM to jonnywalk
Torque
If my understanding of the defination of torque is correct and i think it is then the output torqe of the motor is related to the voltage and no matter how you gear it you still get the same torque but by gearing you are essentially (and I say this for simplicity's sake) spreading the torque out over a larger time or concentrating it. The real advantage to gearing is you keep the motor turning so you don't stall it out. The same principle with a car, you have the same torque and horsepower in every gear but unless you car is really REALLY powerful you have to reduce it so you don't stall out until you get into higher into the power band. Hope this helps some.
Thunder Chicken CCT Simon G Motors 4 03-01-2003 13:18
Drivetrain help thedillybar Technical Discussion 9 08-01-2002 21:54
Drivetrain Help Jordan Technical Discussion 16 02-12-2001 12:14
Drill motor gearBox question Dennis Hughes Motors 4 11-10-2001 07:11
