Go to Post You have not only joined a robotic competition, you will discover that you are becoming a member of a very large and wonderful family. The more years that you participate, the larger your FIRST family will become. - Car Nack [more]
Unread 26-03-2003, 09:19
FRC Key Volunteer Trainer
AKA: CrazyNate
Originally posted by Jnadke
When comp_mode is 0, your robot is active. Basically, make your if statements to read:
If auton_mode = 0 or comp_mode = 1 or rc_sw14 = 0 then skip_Blah
After the initial powerup sequence on the field causing problems with some autonomous programs, FIRST has switched the bit toggle sequence to(If i understood what Eric told me correctly):
Pre Match: auton_mode = 0, comp_mode = 1
Human Player Phase: auton_mode = 1, comp_mode = 1
Autonomous Phase: auton_mode = 1, comp_mode = 0
Remote Control Phase: auton_mode = 0, comp_mode = 0
Post Match: auton_mode = 0, comp_mode = 1
So, what I'm going to recommend is that your code only starts running in autonomous if BOTH auton_mode and comp_mode are in the states described above. As an FYI, FIRST changed this after realizing that with the original field control code, it was possible for one or two program loops at match start that the PBASIC program would think that it was in user control mode, and possibly skip over the auton program entirely(see other threads on this).
Nate Smith
nsmith@smythsoft.com
Programming Autonomous mode Jared Stofflett Programming 3 11-11-2003 09:32
Autonomous mode AntmanIV General Forum 1 17-02-2003 13:30
autonomous mode timer Don Programming 6 09-02-2003 22:16
autonomous mode Stephanie Programming 2 25-01-2003 19:57
autonomous mode? bigwalt Technical Discussion 1 21-01-2003 01:14
