Go to Post If you are stupid about this and violate the rules, and thereby cause your alliance to lose a match, then your alliance partners will gang up on you and violate your robot. - dlavery [more]
Unread 26-03-2003, 23:53
You have to be a little more specific. Custom circuit boards can be designed to do almost anything from monitor current to full sensor and control. Our autonomous mode is handled with a custom circuit board. It takes input from a variety of sensors and the gyro. As long as the custom circuit does not talk directly to motors and motor control does not pass through the box, the possibilities are endless.
message boards, chat rooms, etc archiver 2001 9 24-06-2002 03:55
circuit breaker archiver 2001 2 23-06-2002 23:18
So what's in YOUR Custom Circuit this year? kmcclary Technical Discussion 7 10-04-2002 12:20
Wiring custom toggle switches into operator interface DanL Electrical 9 13-02-2002 17:13
custom circuit boards ctartist236 Technical Discussion 5 08-01-2002 00:10
