Go to Post We are all insane aren't we? I just want to build a robot now. :P - Lowfategg [more]
Unread 19-01-2002, 11:25
schitnis schitnis is offline
schitnis is an unknown quantity at this point
Originally posted by Eric Reed
Here's how I understand it: Hardened steel is hardened on the skin only, and when you turn the shaft you remove that skin...the inside is much weaker. So after you turn the shaft, you have to heat treat it. We would have to have someone do this for us, as we have neither the equipment nor the expertise.
Use Graphite (also refered to as grey powder) and dip redhot steel in it.
Use oxyacytyline torch to do so. If you use a furnance, u will deform it.
Regards
schitnis
Team 915
Can you stop a pneumatic pump at half shaft mjt902 Pneumatics 16 06-02-2003 11:58
Curie Division Robots information... (not complete) archiver 2001 3 24-06-2002 03:13
Team 188 Pictures - four big balls anyone? archiver 2001 6 24-06-2002 01:03
Motor coupling archiver 2001 19 23-06-2002 23:35
using set screw or dowel pin/pin to hold on drill motor coupler thinggy Travis Covington Motors 1 04-02-2002 03:02
