Go to Post "If all else fails, use a bigger hammer" - Steve Florence - Logan Byers [more]
Unread 19-01-2002, 01:46
Anton Abaya's Avatar
Anton Abaya Anton Abaya is offline
None #0419 (Rambots)
Anton Abaya has a spectacular aura aboutAnton Abaya has a spectacular aura aboutAnton Abaya has a spectacular aura about
Send a message via ICQ to Anton Abaya Send a message via AIM to Anton Abaya
Big Shaft to Little Shaft?
Whats the best way teams have connected a smaller diameter shaft to a larger diameter shaft. Say 5/16" to a 1/2" ? or a 3/8" to a 1/2"?
-anton
Unread 19-01-2002, 09:53
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Re: Big Shaft to Little Shaft?
-anton
Our plan was to start with the larger diameter shaft and turn it down on a lathe to get the smaller diameters where appropriate.
--Madison--
...down at the Ozdust!
Unread 19-01-2002, 11:00
Eric Reed Eric Reed is offline
I am somebody now!
#0481 (De Anza Robotics Team)
Eric Reed will become famous soon enoughEric Reed will become famous soon enough
Be careful to harden the shaft after you do this! Last year we turned a shaft in exactly this way, and the shaft sheared on the field, leaving us with no drive system for the next two matches.
Here's how I understand it: Hardened steel is hardened on the skin only, and when you turn the shaft you remove that skin...the inside is much weaker. So after you turn the shaft, you have to heat treat it. We would have to have someone do this for us, as we have neither the equipment nor the expertise.
Good luck,
Eric.
Unread 19-01-2002, 11:25
schitnis schitnis is offline
schitnis is an unknown quantity at this point
Use Graphite (also refered to as grey powder) and dip redhot steel in it.
Use oxyacytyline torch to do so. If you use a furnance, u will deform it.
Regards
schitnis
Team 915
Unread 20-01-2002, 05:24
It might help to make the transistion less abrupt, as well, to "spread out the stress"; a sharp transistion is a stress riser. The advice on heat treatment is well taken, though.
Unread 20-01-2002, 12:32
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
You can do a reasonable job of heat-treating in a small shop (or even in your kitchen, but we will get to that in a moment). Eric Reed is correct; in most situations when you turn down a shaft you will remove any surface heat treating/hardening (depending on how the material was originally manufactured). If you have annealed the piece prior to working it, it is guaranteed that the heat-treating has been removed. To get it back, you will need to re-harden and then temper the steel.
Once the piece has been manufactured (turned, milled, filed, finished or whatever) reheat the entire piece with a torch until it is cherry red (around 1650 degrees F). Holding it in a pair of tongs (not your hand - duh!) quickly plunge it into a bucket of water (OK) or oil (preferred). You want to plunge it straight in vertically (i.e. along the length of the piece), and not sideways, to make the stresses within the piece as even and consistent as possible. For the same reason, swirl the piece in the liquid in a figure-8 pattern, and not in a circular pattern, until it cools. This will ensure that fresh surfaces of the piece are exposed as it moves through the liquid, and makes the cooling as even as possible.
Once the piece has cooled down to about 100 degree F, the hardening step is done. The piece is nice and hard, but it is also brittle (with good tool steels, if you drop the piece on a concrete floor at this stage it will frequently shatter). You need to temper the piece to draw back the hardness of the surface material into a stronger, less brittle form, and relieve internal stresses. Take a file or some emery paper and scrape the surface of the piece to reveal fresh metal. You will need to evenly reheat the piece to the tempering stage, and then quench it again. While it is possible to do this with a torch, it is difficult. The easiest way is to heat it in a kitchen oven (I will leave it to you to determine if you want to ask Mom before or after you do this). Depending on the alloy you have, you need to get the piece up to about 460 degrees F. At this temperature, this fresh exposed metal will turn a straw yellow color. Watch the color carefully - this is your best indication of when the steel has tempered. If it goes past yellow into brown or purple, it is too hot and you need to start over from the hardening step. Once it is straw yellow, take it out of the oven and requench it immediately. When it has cooled, you are all set.
This isn't a perfect process that you would use for large-scale production, but it is a reasonable small-lot method. Knife makers and blacksmiths have been using this technique successfully for ages. You will have a nice hardened piece that should stand up under the stresses your robot will see.
-dave
Unread 21-01-2002, 06:29
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Ruland makes a killer coupler
From McMaster Part Number 61005k52 3/8 to 1/2 rigid shaft couplings. They are clamp on couplings -- no set screws!
I really like these couplers, though they are no particularly light.
Joe J.
P.S. Pay attention to the torque ratings.
Unread 21-01-2002, 19:27
Justin Stiltner's Avatar
Justin Stiltner Justin Stiltner is offline
The big guy
Justin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud of
Send a message via ICQ to Justin Stiltner Send a message via AIM to Justin Stiltner Send a message via MSN to Justin Stiltner Send a message via Yahoo to Justin Stiltner
We always took a peice of shaft that was thicker than the thickest of the shafts and threw it in a lathe and made a coupling for it with cross drilled pins.
it worked for our really high torque applications.
and its ultra simple and cheap
Justin Stiltner
Lead Robot Inspector, VCU Regional
Unmanned Systems Lab, Virginia Tech
KI4URQ
Can you stop a pneumatic pump at half shaft mjt902 Pneumatics 16 06-02-2003 11:58
Curie Division Robots information... (not complete) archiver 2001 3 24-06-2002 03:13
Team 188 Pictures - four big balls anyone? archiver 2001 6 24-06-2002 01:03
Motor coupling archiver 2001 19 23-06-2002 23:35
using set screw or dowel pin/pin to hold on drill motor coupler thinggy Travis Covington Motors 1 04-02-2002 03:02
