Go to Post I'm unconvinced that this thread itself is not a performance art piece. - DCA Fan [more]
Unread 20-01-2002, 11:09
President, VEX Robotics, Inc.
Gear Data
I will try to answer a few questions:
1) The pressure angle of the 16 tooth part of the cluster gear is 20°.
2) We just bought the motor and gearbox from Anderson and they spin the cluster gear right on a steel shaft. The gear has some brass content (copper, etc) and is a pretty good bearing.
We are rotating the gear directly on a hardened 1/4" shaft. The shaft should have a slight press fit into one end of your housing or you can put a clip ring on the end. Attached is our 3-D representation of how we are attaching it.
Hope this helps
Thunder Chicken CCT Simon G Motors 4 03-01-2003 13:18
Cheap small gear source archiver 2000 2 23-06-2002 22:33
Drivetrain help thedillybar Technical Discussion 9 08-01-2002 21:54
Drivetrain Help Jordan Technical Discussion 16 02-12-2001 12:14
