Go to Post it should not matter the gender of a person but rather their ability. - vivek16 [more]
Unread 30-03-2003, 15:33
Greg's Avatar
Greg Greg is offline
FRC #1075 (Sinclair Sprockets)
Greg is on a distinguished road
Send a message via ICQ to Greg Send a message via MSN to Greg
Question Replacement for Bevel Gears?
I think everyone who saw our bot at the Canadian Regional could hear those bevel gears grinding away when some load was applied to the bot If we have a chance to go to another competition this year, we would definitely like to fix our drive unit.
So, what is a better alternative to bevel gears? Do you think worm gears are stronger? Or can we eliminate the grinding somehow?
The gears are already as tightly meshed as possible, but when the track gets stuck, the torque from our 4 drive motors rips the gears apart Any suggestions?
Unread 30-03-2003, 15:40
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
The ones in the kit were helical gears. Bevel gears are quite different. Maybe one team would be willing to trade or give them if they are not being used.
Unread 30-03-2003, 16:05
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
As mentioned previously, the ones in the kit are Helical gears. Are these the ones you are talking about or did you use bevel gears for something else?
Anyways, if you are talking about the helicals, I can tell you that we used them this year without any problems whatsoever. The key is to make sure you have spacers that are the correct size inside the gearbox and to make sure the shaft can't "walk" out of the gearbox. Here's some pics of our 'bot, which uses both the Chips and the Drills driving the gearboxes provided by FIRST:
http://www.cogsquad.org/image.php?id=34
http://www.chiefdelphi.com/forums/pi...gle&picid=4614
Unread 30-03-2003, 19:56
Greg's Avatar
Yep, I've been thinking about these helical gears... To use them we'd have to move one of the shafts down quite a lot. I dont think we have the space, but I'll look at it again when I go to school tomorrow.
We use "extra" bevel gears (that means they were not in the kit). We talked about all these drivetrain problems today, and it looks like we need to support the shafts better (they started to bend - we have tons of power!). This may eliminate the grinding, even with the same type of gears.
Helical gears that come with new drill motor Joe P Technical Discussion 4 12-01-2003 11:09
Best source for gears? Smallparts? drivetrain advice wanted! Frank(Aflak) Technical Discussion 11 10-01-2003 17:22
Need help! What kind of gears are we allowed to use?? Randy_Ai Technical Discussion 3 23-01-2002 22:56
replacement gears joni_m Technical Discussion 1 22-01-2002 18:01
Are gears really this expensive? Anton Abaya Technical Discussion 2 13-01-2002 22:23
