Go to Post We put our alumni to work. That either benefits all or drives them out for good. :) - Wayne C. [more]
Unread 21-01-2002, 14:32
kangarue23 kangarue23 is offline
kangarue23 is an unknown quantity at this point
Wiring for the pressure switch...?
Our team just found out that pressure switches actually serve a purpose (from reading this thread) but now we're kind of confused. How do you wire a pressure switch (12v, ground & signal...?) Thanks in advance.
Does your team use the Default code. Jeff McCune General Forum 2 09-01-2003 14:46
What are pneumatics? Aignam Pneumatics 23 16-10-2002 21:17
Need help with 255 Variable Joseph F Programming 18 26-02-2002 14:49
Error found in programming for the pump and pressure switch sjharobotics Programming 4 06-02-2002 17:46
Pneumatics pump allowed on robot? bigqueue Pneumatics 5 06-01-2002 12:30
